Motor mounts for my dual cammer ZC
I know and Im using my OEM Honda mounts, but they are fucked up, i can replace them but aftermarket mounts look and might be better. So does Anyone know of a company that makes aftermarket motor mounts for my DOHC ZC in my 88 hatch? TIA
The mounts are the SAME as the USDM ones.
You really don't even have to replace your beat up ones.
You can get some ES bushings for the USDM mounts and put them in there and it will stiffen them up nicely.
There is also a cheapo alternative where you just fill the mount with silicone.
cant think of any companies other than HAsport, BUT going with the stock mounts would prolly be best. most aftermarket mounts and bushings are polyurethane, and they sqeak like none other. stick to rubber mounts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ponchep3 »</TD></TR><TR><TD CLASS="quote">cant think of any companies other than HAsport, BUT going with the stock mounts would prolly be best. most aftermarket mounts and bushings are polyurethane, and they sqeak like none other. stick to rubber mounts</TD></TR></TABLE>
Never heard an poly engine mount sqeak. But they do transfer more vibrations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton »</TD></TR><TR><TD CLASS="quote">
Never heard an poly engine mount sqeak. But they do transfer more vibrations.</TD></TR></TABLE>
Neither have I but I wouldn't give a rat's *** about the more vibrations....I want it "zippier"...
hard_boiled_EG
Dec 10, 2009 08:39 PM
D16SohcVtec
Aug 12, 2008 08:03 AM
JapJunkie
Aug 4, 2004 10:17 AM
racingant
10
Mar 13, 2004 07:17 PM
