MOTUL Gear 300 -- BAD
Old Aug 27, 2004 | 01:22 PM
Flux's Avatar
Default MOTUL Gear 300 -- BAD
I just got back from my mechanics shop to have the trnasmission fluid changed. I went there planning on putting in the MOTUL Gear 300 due to conversations on this board and some recommendations. My mechanic, who is very trusted and has been working on Hondas for decades, refused to put it in and said it would damage the tranny and eventually lead to failure.
Just an FYI and another opinion for those thinking about changing tranny fluid.
Old Aug 27, 2004 | 01:23 PM
MattD@Stoptech's Avatar
Default Re: MOTUL Gear 300 -- BAD (Flux)
en den.....?
did he elaborate?
Old Aug 27, 2004 | 01:25 PM
1GreyTeg's Avatar
Default Re: MOTUL Gear 300 -- BAD (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">en den.....?
did he elaborate?</TD></TR></TABLE>
Me = also curious, despite picking up my Honda MTF the other day.
Willard's Avatar
RJ = sux.
Old Aug 27, 2004 | 01:29 PM
Johnny Tran's Avatar
Default Re: MOTUL Gear 300 -- BAD (Willard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard &raquo;</TD></TR><TR><TD CLASS="quote">RJ = sux. </TD></TR></TABLE>
nah......his MOM does however.
btw, shes under my desk right now
Old Aug 27, 2004 | 01:31 PM
Default Re: MOTUL Gear 300 -- BAD (Johnny Tran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny Tran &raquo;</TD></TR><TR><TD CLASS="quote">
That must be SOME desk.
Old Aug 27, 2004 | 01:34 PM
That must be SOME desk.</TD></TR></TABLE>
lmfao! touche'
:FIRE:
Old Aug 27, 2004 | 01:51 PM
Bbasso's Avatar
:FIRE:
Damm this thread is on fire already...
Old Aug 27, 2004 | 02:03 PM
Default Re: MOTUL Gear 300 -- BAD (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">:FIRE: </TD></TR></TABLE>
so is my *** after wings last night
:fire: x 2
Old Aug 27, 2004 | 02:08 PM
Big Phat R's Avatar
Been using Motul for 3 years - no problems on my car - which is used/abused at the track a LOT
Old Aug 27, 2004 | 02:20 PM
Splat's Avatar
Collector-o-Guns and Drinker
Old Aug 27, 2004 | 03:23 PM
Dirt's Avatar
Default Re: (Splat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
best l0g0 evAr.
Old Aug 27, 2004 | 03:25 PM
Rob Dizzle's Avatar
Default Re: (Splat)
the thing with mechanics. is that they always think that they are right.
did you ask him why he doesnt like motul?
has he done tests to compare results and whatnot?
Sometimes its internetesque in how they turn against a certain product. The mechanic near me likes this oil called synergyn and doesnt like redline at all. If I ask him why, he gives me some illogical answer and says that synergyne is the only oil he uses on his daily driver, and race car.
Well just because he has never tried redline, and sent each oil to a lab, he sure as hell isnt any expert on oils despite his mechanical knowledge.
Critical Thinking/Reasoning is a very useful lifeskill
Old Aug 27, 2004 | 03:30 PM
nsxtasy's Avatar
H-T Order of Merit
Oh, COME ON! .RJ has 21620 posts where you can flame him in response to his posts. You don't need to flame him in topics where he hasn't posted. That's not fair.
Damm this thread is on fire already... </TD></TR></TABLE>
You guys started the party without me! I'm feeling so left out.
Old Aug 27, 2004 | 04:01 PM
Dr Pooface's Avatar
Default Re: MOTUL Gear 300 -- BAD (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote"> My mechanic, who is very trusted and has been working on Hondas for decades, refused to put it in and said it would damage the tranny and eventually lead to failure.</TD></TR></TABLE>
Your mechanic has an opinion. The great thing about opinions is that inherently, they cannot be "wrong". Doesn't stop it from being stupid, non the less.
Motul makes some of the best automotive lubricants available. The idea that their tranny fluid would lead to a tranny failure is simply laughable.
edit: ftr I use redline.
Old Aug 27, 2004 | 04:08 PM
mtber's Avatar
Use GM friction modified syncromesh :-)
Old Aug 27, 2004 | 04:10 PM
uNF$@#!'s Avatar
yay, more bandwagon bullshit for rapid tranny failure with the GM syncrowear fluid.
getting back to OP, i'm curious why a mechanic would say such a thing...
then again, i spoke to a mechanic long ago who seemed to know everything and condemned synthetic motor oil because it destroys the gaskets.
Old Aug 27, 2004 | 05:07 PM
Dan GSR's Avatar
&lt;-- uses a super secret blend of MTF
Old Aug 27, 2004 | 05:17 PM
Cyber ITR's Avatar
Default Re: (w@@t w@@t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t &raquo;</TD></TR><TR><TD CLASS="quote">yay, more bandwagon bullshit for rapid tranny failure with the GM syncrowear fluid.</TD></TR></TABLE>
what makes u said that gm synchromesh leads to a gearbox failure ??
Old Aug 27, 2004 | 05:30 PM
Mugen Type R's Avatar
GM synchromesh is a baid aid solution, if your synchros are fucked you need a rebuild no oil will fix it, so if the grinds stop with gm synchormesh, at one point, all hell can and will break lose in your tranny in due time.
Old Aug 27, 2004 | 05:59 PM
EKCivicR's Avatar
There are many conclusions to this problem... first of all being how old your tranny is and how long has the current lube been building up gunk and all?
Sometimes when you input a new lube of a different kind, advanced or not, it can cause leaks and failures do to the properties contained within the more advanced lubes.
Take for an example lets say you have about 60-70K on your tranny and have been using honda mtl the whole time. Switching over to a more advanced lube will deteriorate the gunk build up from years of driving. Simply the detergents get rid of the bad stuff and the new stuff needs time lube properly. Thus causing trannies to go bad. Sometimes this can be fixed by simply flushing your transmission and refilling new fluid.
Old Aug 27, 2004 | 06:17 PM
Kengs's Avatar
Just an FYI and another opinion for those thinking about changing tranny fluid.</TD></TR></TABLE>
Jonathan, you should inform your mechanic that Honda MTF-II (sold in Japan) is a full synthetic. FWIW, I've used HKS FF Gear (similar to Motul Gear 300) for over 3 yrs w/o any problems.
Old Aug 27, 2004 | 07:27 PM
Tweakmeister's Avatar
Default Re: MOTUL Gear 300 -- BAD (Dan GSR)
I use sheep's blood
Old Aug 27, 2004 | 07:29 PM
Misfit's Avatar
Default Re: MOTUL Gear 300 -- BAD (Tweakmeister)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tweakmeister &raquo;</TD></TR><TR><TD CLASS="quote">I use sheep's blood</TD></TR></TABLE> you told me it was goat
Old Aug 27, 2004 | 07:50 PM
ejprimo's Avatar
Default Re: MOTUL Gear 300 -- BAD (kengs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kengs &raquo;</TD></TR><TR><TD CLASS="quote">
Jonathan, you should inform your mechanic that Honda MTF-II (sold in Japan) is a full synthetic. FWIW, I've used HKS FF Gear (similar to Motul Gear 300) for over 3 yrs w/o any problems.</TD></TR></TABLE>
yeah, but in america....
