What exactly would i need to run 10-12 pounds on stock internals?
Old Dec 4, 2001 | 04:37 PM
chuckd05's Avatar
New User
Default What exactly would i need to run 10-12 pounds on stock internals?
What exactly would i need to get to run 10-12 pounds safe on stock internals. I am thinking bigger injectos (not sure on size), AFC-R, possibly bigger head gasket, and what else? Is it possible? Right now im at 6 and im not sure if its safe to put up. Also if i got a AFC now whats the best way to set it up. I am totally not aware of how to work them.
Old Dec 4, 2001 | 04:47 PM
D-SPEED's Avatar
Default Re: What exactly would i need to run 10-12 pounds on stock internals? (chuckd05)
some good tuning...i would be scared to go without something like hondata....good ignition and fuel control is essential
Old Dec 4, 2001 | 05:03 PM
TurboSedan's Avatar
New User
Default Re: What exactly would i need to run 10-12 pounds on stock internals? (D-SPEED)
That boost level is fine with good tuning. I would get a standalone for that boost level on stock internals if you care about the engine much. I personally plan to use a Hondata Stage 2B on a D16 and run 10PSI daily until I am too used to it. After that happens we'll do a GM 3 Bar MAP sensor upgrade and see how much fun we can have then!!!
Old Dec 4, 2001 | 05:15 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: What exactly would i need to run 10-12 pounds on stock internals? (97CivicFerio)
You are going to have to have like the perfect fuel setup on that ride for that many pounds, recommend 6 daily, 10 max dude, unless you or someone you know can tune like a bad motha.
Old Dec 4, 2001 | 08:27 PM
FIxALPHA's Avatar
Default Re: What exactly would i need to run 10-12 pounds on stock internals? (ForcedAccord)
I think Im pushing it myself. I have stock internals and boosts 11.5psi. With the right tuning and fuel set up (like what everyone else on the thread stated), it should be fine, but don't know how long it will hold.
I've had this setup for a year and a half. My first motor went, cracked ring lands, and this second stock motor is holding up well.
Old Dec 5, 2001 | 09:55 AM
TurboSedan's Avatar
New User
Default Re: What exactly would i need to run 10-12 pounds on stock internals? (FIxALPHA)
I hear ya Forced Accord, I have a tuner in my area named Tom Payne. I think he knows hiw stuff.
Old Dec 5, 2001 | 10:03 AM
DIRep972's Avatar
Smarter than you
Im planning to run hondata with 550's and boost my STOCK LS motor up to 15psi on 114 octane..
crx6662
Feb 22, 2010 09:26 AM
miamiboy91
Feb 8, 2009 07:37 PM
chattownrexer
Aug 30, 2004 08:05 PM
elementmilwaukee
Apr 29, 2004 01:07 PM
TurbodCX
Oct 16, 2003 11:23 AM
