shat! i think my AC Condenser just died! grind grind clunk clunk squeak squeak
Old Aug 27, 2004 | 08:56 AM
supadupamikey's Avatar
Default shat! i think my AC Condenser just died! grind grind clunk clunk squeak squeak
so i jumped in my car at lunchtime to run some errands and went a couple miles and i noticed a loud squeaking after taking a slight turn. i thought.. hmm, thats weird, maybe im low on ps fluid... then a few seconds later it started squeaking again... but this time i was going straight so it wasnt the ps fluid... i quickly hit the a/c button to turn the a/c off and the noise stopped. i push the a/c button again (to turn it back on) and i hear this slight clunk clunk noise and then that squeaking again.... poop!
its 93 degrees outside and i think my a/c condenser just died!
any input? is that what died?
we're planning on taking a 1200 mile road trip this coming thursday so i need to fix this asap! i'll need to replace the a/c condenser and then evacuate/charge the refrigerant again, right?
thanks guys!
EDIT : I MEANT COMPRESSOR, not condenser
Modified by supadupamikey at 2:15 PM 8/27/2004
Old Aug 27, 2004 | 09:34 AM
hatchdrvr's Avatar
Default Re: shat! i think my AC Condenser just died! grind grind clunk clunk squeak squeak (supadupamikey)
check sig, I have a/c parts for sale, cheap.
Old Aug 27, 2004 | 10:33 AM
Default Re: shat! i think my AC Condenser just died! grind grind clunk clunk squeak squeak (hatchdrvr)
anyone else?
does the compressor normally go bad? or just the clutch?
whats involved in changing the clutch? can i change the clutch with the compressor still on the car? so, i wont need to evacuate/recharge?
sorry, its a 96 civic ex with 120k miles
Old Jul 21, 2006 | 11:33 AM
95TEG's Avatar
I am having the exact problem, so is it the A/C condenser??? PLZ Help ASAP!!!!
Old Jul 21, 2006 | 05:01 PM
o5mar1's Avatar
its not the condensor, its the compressor. the condensor turns the vapor a/c into a liquid hence the name condensor, it condenses. now yes you can change the clutch with out removing the compressor. but i think the compressor is bad.
JDM.Accord
Aug 1, 2012 10:26 AM
m1ndless
Aug 28, 2006 03:54 PM
ZexyAccord
Mar 5, 2005 04:17 AM
haydent
Sep 3, 2002 01:51 PM
