Quick Dizzy question.
Old Aug 27, 2004 | 08:41 AM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Quick Dizzy question.
I have a B16 and I want to go obd1... my question is: Can I just buy a dizzy from a D16, or do I have to find like a obd1 del sol dizzy or GSR or something?
Old Aug 28, 2004 | 05:09 AM
Default Re: Quick Dizzy question. (Jurassic Four)
My question is: Will D series distributers fit on B series motors?
Old Aug 28, 2004 | 04:37 PM
Come on... some one has to know this.
Old Aug 29, 2004 | 05:41 AM
Thanks Honda Tech for your awesome technical answers!
Old Aug 29, 2004 | 06:28 AM
mmuller's Avatar
Mad Scientist
NO
Old Aug 29, 2004 | 07:34 AM
Default Re: Quick Dizzy question. (mmuller)
Thanks Thats all I needed.
Old Aug 29, 2004 | 11:10 PM
jmonee112's Avatar
actually i think my buddy has a crx dizzy on his b18a i will ask him tomorrow and make sure, and see how he did it..
Old Sep 2, 2004 | 05:13 PM
Default Re: Quick Dizzy question. (jmonee112)
?? What did he say?
Old Sep 2, 2004 | 05:41 PM
sol_guy8569's Avatar
A d-series distributor won't fit on a B16 motor. I tried it and the bolt pattern is different.
Old Sep 2, 2004 | 07:58 PM
jmonee112's Avatar
Default Re: Quick Dizzy question. (sol_guy8569)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol_guy8569 &raquo;</TD></TR><TR><TD CLASS="quote">A d-series distributor won't fit on a B16 motor. I tried it and the bolt pattern is different.</TD></TR></TABLE> B series motor mounts have diff bolt patterns than a d series motor mounts...but the motors can be swapped between chassis with a little modification... just cause the bolt pattern is diff doesn't mean it wont work. Tell you what, make sure the plug wire order is correct, make sure the timng is set, and go out there and HOLD a d-series dizzy on your b-series and have a buddy crank it over. It WILL start as long as you have the correct dizzy for the obd you are running. After that you can eyeball how it will bolt up...maybe only use two fins?? a bracket?? If I have to I can check to see exactly how my buddy did his if you are wondering.. this is result of no budget honda building..lol
Old Sep 6, 2004 | 10:36 AM
I just went out and forked out the $250 for a new dizzy .
civickiller
Apr 17, 2011 07:43 PM
Ep1dem1c
Jun 28, 2007 09:23 AM
efrex
Jan 22, 2006 05:39 PM
v8killa121
Oct 3, 2005 02:39 PM
89silverb16crx
Apr 13, 2004 08:37 AM
