Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Best LUG NUTS to buy?
Old Aug 27, 2004 | 08:40 AM
slomosi's Avatar
Default Best LUG NUTS to buy?
What do you guys recommmend? VOLK, Work, buddy club,mugen, etc....thanks
Old Aug 28, 2004 | 12:35 AM
slomosi's Avatar
Default Re: Best LUG NUTS to buy? (slomosi)
anyone??
Old Aug 28, 2004 | 01:55 AM
AzntaggeR's Avatar
TSPeed Factory
they're all basically the same thing. if you were goin to pick from those or any other expensive lug nuts i'd go with the rays just because it has the 7 sided lug nut for extra security.
Old Aug 28, 2004 | 08:14 AM
slomosi's Avatar
cool thanks...that's what i was thinking....
Old Aug 28, 2004 | 08:26 AM
BigZ88's Avatar
first off, i'm sure you are buying these for aftermarket wheels as they should not be used with OEM wheels no matter what anyone tells you.
Second, if you do buy aluminum lugs, i suggest ALWAYS use a torque wrench to the specified torque specifications of the new lugs. (not doing so is the main reason people strip out aluminum lugs and call them crap)
It has also been suggested to use some anti-seize on the lug studs before you put the lugs on.
Old Aug 28, 2004 | 08:46 AM
Ricey McRicerton's Avatar
Default Re: Best LUG NUTS to buy? (BigZ88)
Very good point Z28. OEM rims have an acorn style lug seat whereas most aftermarket rims and lugs have a tapered style lug seat. Using aftermarket lugs on an OEM rim will cause problems over time.
Old Aug 28, 2004 | 08:49 AM
WAFFLES's Avatar
Default Re: Best LUG NUTS to buy? (Ricey McRicerton)
Also if finish is a concern for you remember that most colored lugs fade. My friend has some red spoon lugs that are now pink.
Old Aug 28, 2004 | 08:53 AM
TheKidd's Avatar
I have the skunk2 lug nuts and have no problems with them.
Old Aug 28, 2004 | 10:04 AM
BigZ88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Very good point Z28. OEM rims have an acorn style lug seat whereas most aftermarket rims and lugs have a tapered style lug seat. Using aftermarket lugs on an OEM rim will cause problems over time.</TD></TR></TABLE>
Z88
anyways, I actually dont think honda's have an actual acorn style either. Its more of a ball type seat. While at SEMA I talked to 3 seperate lug manufacturers to see if they made an aluminum or any other type of aftermarket lug to fit honda wheels and they said no and had no plans to make one. I was dissapointed. The best response I got was from the guys at Gorilla. They actually seemed somewhat interested when I mentioned how many honda guys run factory wheels
Old Aug 28, 2004 | 10:21 AM
138's Avatar
138
all of those lug nuts will work fine. just get what you like best.
my old rays:
Old Aug 28, 2004 | 10:26 AM
jdmitr01's Avatar
Default Re: Best LUG NUTS to buy? (TheKidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKidd &raquo;</TD></TR><TR><TD CLASS="quote">I have the skunk2 lug nuts and have no problems with them.
VERY NICE NICE...
Old Aug 28, 2004 | 10:27 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: Best LUG NUTS to buy? (jdmitr01)
pep boys
Old Aug 28, 2004 | 12:29 PM
slomosi's Avatar
Default Re: Best LUG NUTS to buy? (BLUE EH3)
i really like the RAYS black extended lugs. what do you guys think of those?
Old Aug 28, 2004 | 01:14 PM
TallAssFilipino's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigZ88 &raquo;</TD></TR><TR><TD CLASS="quote">first off, i'm sure you are buying these for aftermarket wheels as they should not be used with OEM wheels no matter what anyone tells you.
It has also been suggested to use some anti-seize on the lug studs before you put the lugs on. </TD></TR></TABLE>
I was actually told that it's not a good idea to use anti-seize on the lug studs/nuts. When I did... opps! There goes the rim. And yes they were on there tight enough as I'm always self-conscious about that kind of stuff.
Old Aug 28, 2004 | 01:33 PM
slomosi's Avatar
Default Re: Best LUG NUTS to buy? (TallAssFilipino)
what's anti-sieze?
Old Aug 28, 2004 | 01:38 PM
dmotoguy's Avatar
a paste that people put on some studs to help prevent the nut from siezing
Old Aug 28, 2004 | 02:44 PM
Icey112's Avatar
the mugen ones are hot the say mugen on the side of them.
Old Aug 28, 2004 | 04:19 PM
xerox445's Avatar
Default Re: (Icey112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 &raquo;</TD></TR><TR><TD CLASS="quote">the mugen ones are hot the say mugen on the side of them.</TD></TR></TABLE>
daym, no way nucca...
Old Aug 28, 2004 | 06:25 PM
jmk2888's Avatar
I got Gorilla Black Nuts on my 57C from JC Whitney.
They're cheaper than Rays.
http://www.jcwhitney.com/autop...10101
Old Aug 28, 2004 | 08:28 PM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
gorilla nutz baby
Old Aug 28, 2004 | 08:36 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (SpoolinEK9)
skunk2's here
Old Aug 28, 2004 | 08:40 PM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (Hella_JDM)
gorillas, or something of the sort
Old Aug 28, 2004 | 08:43 PM
FF lotus's Avatar
Default Re: (turtlecx92)
chrome acorns
Old Aug 28, 2004 | 08:49 PM
OnePointFive's Avatar
overrated.
Default Re: (FF lotus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FF lotus &raquo;</TD></TR><TR><TD CLASS="quote">chrome acorns </TD></TR></TABLE>
good call all you suckers that pay more than $25 for lugnuts are idiots.
Old Aug 28, 2004 | 08:51 PM
Blk00EJ8's Avatar
Kyokugen aluminum nuts... light and heptagonal for security. Got mine for $43 a set of 20.
