Where and what Kind of 450CC Injectors??
Setting up my fuel system to be turbo'd, wondering where I should look for these 440-450CC injectors everyone is talking about. Is the Walbro 255 an inline pump or in tank pump?
walboro 255 is in in tank pump...the injectors you are probably referring to are ones from a dsm...if not, just go with RC's...
Not true, mine is obd2 and it uses obd1 style clips with a resistor box. You just have to look at your setup to find out what you need.
alright...
someone tell me what to google or ebay for.. some engineering specs?
so far im trying to dig up something with this "RC 440 Injector Accord" in google...
will any Saturated injector work on the accord?..?
Is it necesarry for 9psi boost to use injectors or will the stock do (as good) on a 9psi T3 setup /w 3" exhaust.
Are those prices I see per injector or per set?
RC 440 injectors usually go for around $89 USD each. that means that you will need to pay 4 times that much for a set, plus the money for the adapter clips if you need them. as far as i know, any saturated injector will work with any honda OBD1 or 2 car. another thing you have to consider is how you are going to tune those new injectors, as your factory ECU will be totally confused. Personally I am using the RC 440s with Emanage. I am running a T-25 at 8psi and have got the A/F ratio nearly perfectly flat at 12.1. Emanage is a bitch to program though, but it does work well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowboost »</TD></TR><TR><TD CLASS="quote">RC 440 injectors usually go for around $89 USD each. that means that you will need to pay 4 times that much for a set, plus the money for the adapter clips if you need them. .</TD></TR></TABLE>
holy rip off batman! thats 356 a set, your getting screwed hard.
they sell for 260-265 ish.. thats 66-67 each.. need to shop around and check you sources.
yeah 89 a piece is way too much.
you can get a whole set of cleaned/ flowed dsm's for 50-60 bucks... I went that route and could not be happier with them. until I soon need bigger that is.
you can get inline and intank pumps from alot of different companies... intank is more installion work but I would go that route.
