1991 Honda Accord Fan Won't Shut Off
Old Aug 27, 2004 | 04:32 AM
Batchs's Avatar
Default 1991 Honda Accord Fan Won't Shut Off
We have a 1991 Honda accord and the fan comes on after we stop the car and does not shut off. We have replaced 3 different parts and nothing seems to work. My mechanic is baffled because he says the 3 parts are the only part it could be. Sorry for being so vague as I do not know the name of the parts.I should also mention that the thermostat gauge in the car also jumps all over the place and says it is always running on hot. But the mechanics have disconnected it and it still shows hot so it is not working correctly.
Old Aug 27, 2004 | 08:05 AM
Hondaman56's Avatar
From: Filthadelphia City of Brothers and Love, PA, USA
Default Re: 1991 Honda Accord Fan Won't Shut Off (Batchs)
When this happend on my Accord it was the fan relay.
Old Aug 27, 2004 | 01:41 PM
Batchs's Avatar
Default Re: 1991 Honda Accord Fan Won't Shut Off (Hondaman56)
Thanks already replaced the fan relay. That did not work.
Modified by Batchs at 9:35 PM 8/27/2004
Old Aug 27, 2004 | 09:19 PM
cmrvi1's Avatar
Have you replaced the fan timer unit located under the glove box?
Old Aug 30, 2004 | 11:06 PM
MR5 EF9's Avatar
Default Re: 1991 Honda Accord Fan Won't Shut Off (cmrvi1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmrvi1 &raquo;</TD></TR><TR><TD CLASS="quote">Have you replaced the fan timer unit located under the glove box?</TD></TR></TABLE>
this man is correct! Do that and youll be fine!!!
Old Sep 9, 2004 | 09:53 AM
Batchs's Avatar
Thanks for your reply - My mechanic checked the manual and it said that the fan timer was under the steering wheel. He called Honda and they say that there is no such part. We all know that there is this part . Is there a chance that it is under the steering wheel or can you tell me where under the glove compartment it is as we have looked and were unable to find anything. Could you tell me what the part looks like (colour etc)
Thanks
Old Sep 9, 2004 | 10:20 AM
James's Avatar
http://www.hondaautomotivepart...RELAY
I seem not able to locate the fan timer here but maybe someone here would be able to locate this for you.
Jim
Old Sep 9, 2004 | 02:58 PM
Batchs's Avatar
Default Re: 1991 Honda Accord Fan Won't Shut Off (James)
Nothing that I can see there.
Old Mar 15, 2013 | 09:39 AM
jackp1's Avatar
The fan timer is to the left of the steering column on models with auto transmission and on the left kick panel wall for models with manual to clear the clutch pedal assembly.. I am still trying to figure out how to get the unit out of a model with manual. It is impossible to reach the bolt holding it. If anybody has done this, please help.
Old Mar 15, 2013 | 11:03 AM
Bad_dude's Avatar
Icon3 Re: 1991 Honda Accord Fan Won't Shut Off
The fan timer on this car is under the dash on the driver's side bolt it on the side panel right above the fuse box. It's a black little box and not the cruise control silver box with the main relay behind. Just stick your head under the steering dash and you'll see it.
Though it rarely goes bad but the best place to get it for cheap is the junkyard.
Old Mar 15, 2013 | 05:23 PM
ReaperMan's Avatar
<a href="http://s1133.photobucket.com/albums/m593/Benjis_Mommy/?action=view&amp;current=Untitled-2.png" target="_blank"><img src="http://i1133.photobucket.com/albums/m593/Benjis_Mommy/Untitled-2.png" border="0" alt="Photobucket"></a>
ReaperMan's Avatar
mr.mightyone
Feb 24, 2015 08:05 PM
junior91hondaac
Oct 27, 2014 12:03 PM
junior91hondaac
Jul 14, 2013 04:33 PM
ddeem1
Sep 25, 2009 10:40 PM
Throwdown
Feb 16, 2006 01:17 PM
