What do you guys think? oil Prob perhaps?
Old Aug 26, 2004 | 08:26 PM
B18C1 '96 Coupe's Avatar
Default What do you guys think? oil Prob perhaps?
What do you guys think? This is what the LS looks like inside.
What should I do? is there a way to clean that?
Old Aug 26, 2004 | 08:28 PM
JDMlyfestyle's Avatar
do a oil change and try that seafoam stuff
Old Aug 26, 2004 | 08:51 PM
Default Re: (JDMlyfestyle)
OK well I need a new Valve cover gasket. I guess als o the seafoam. and an oil change. This motor is out of the car now. I hope it starts.
Old Aug 26, 2004 | 09:10 PM
DelSolSi93's Avatar
Default Re: What do you guys think? oil Prob perhaps? (B18C1 '96 Coupe)
holy shiznit thats one of the worst ive seen sorry to say. I would do a rebuild on the entire motor and hot tank everything
Old Aug 26, 2004 | 09:57 PM
hayabusa160's Avatar
oh my gawd wtf happen there.
was the oil ever changed good god lol
why is it red
Old Aug 26, 2004 | 10:39 PM
b18bcivic's Avatar
Default Re: What do you guys think? oil Prob perhaps? (hayabusa160)
nice red valvetrain
Old Aug 26, 2004 | 10:51 PM
a1320honda's Avatar
Default Re: What do you guys think? oil Prob perhaps? (b18bcivic)
it has ben my experience that pennzoil can do that to a high revving 4cylinder. i know pennzoil is a big, big no-no in dsm's. and that looks the same. if i were you and the motor is out of the car, id yank the head and take it to a shop and have it tanked, but thats just me. good luck
Old Aug 27, 2004 | 07:26 AM
Default Re: What do you guys think? oil Prob perhaps? (a1320honda)
I bought this a while ago. It sat in my garage for 2 months now. and lord knows how long before that.
Is there anyway to clean it? I would think that maybe some kind of engine cleaner would remove some gunk.
I dont know.
Its an LS Unknow milege. And it was auto. If that helps.
Modified by B18C1 '96 Coupe at 9:37 AM 8/27/2004
Old Aug 27, 2004 | 11:53 AM
a1320honda's Avatar
like a couple of us stated, its in your best interest for extended mileage that you pull the motor apart and have everything tanked. theres not anything thats going to clean that motor that you can just dump in it and go. that thing needs to be extensivly cleaned.
Old Aug 27, 2004 | 12:11 PM
DelSolSi93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda &raquo;</TD></TR><TR><TD CLASS="quote">like a couple of us stated, its in your best interest for extended mileage that you pull the motor apart and have everything tanked. theres not anything thats going to clean that motor that you can just dump in it and go. that thing needs to be extensivly cleaned.</TD></TR></TABLE> Again..........
Old Aug 27, 2004 | 12:27 PM
scratchy's Avatar
thats some nasty **** right there, well run some cleaner and try and pick *** much out as possible
Old Aug 27, 2004 | 12:50 PM
redvic's Avatar
Default Re: What do you guys think? oil Prob perhaps? (scratchy)
i have seen that on cars that use penzoil
Old Aug 27, 2004 | 12:52 PM
Devine's Avatar
pshh that aint nothing, you should see the horrible cars we getting coming into my work all day, whenever you get the car running just let the motor idle with 4 quarts of automatic transmission fluid instead of oil. leave it running for about 30 minutes and let it drain, repeat a few times and install your new motor oil, after that replace your oil every 3k miles and be done with it.
Old Aug 27, 2004 | 04:14 PM
ejprimo's Avatar
Default Re: What do you guys think? oil Prob perhaps? (Devine)
use auto-rx. that **** will work.
http://auto-rx.com/
Old Aug 27, 2004 | 07:39 PM
cascaritas's Avatar
Default Re: What do you guys think? oil Prob perhaps? (ejprimo)
yea do the tranny fluid thing it should help
Old Aug 27, 2004 | 07:43 PM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ejprimo &raquo;</TD></TR><TR><TD CLASS="quote">use auto-rx. that **** will work.
http://auto-rx.com/</TD></TR></TABLE>
yup
Old Aug 27, 2004 | 07:46 PM
ABK's Avatar
ABK
Default Re: What do you guys think? oil Prob perhaps? (Sp00n'd Supra)
some one didn't change that oil. Does penzoil really do that ****, my fucked up motor started getting all sludged up the same color after I started using penzoil.
Old Aug 27, 2004 | 11:45 PM
a1320honda's Avatar
Default Re: What do you guys think? oil Prob perhaps? (ABK)
yes, pennzoil is a big no-no in high revving 4-cyl imports. it just doesnt work good
Old Aug 28, 2004 | 03:03 AM
miahmouse's Avatar
hehe... a caramelized valvetrain, you'd be suprised how much of that stuff will come off with just a few oil changes.
Old Aug 28, 2004 | 03:17 AM
EK45VTi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devine &raquo;</TD></TR><TR><TD CLASS="quote">pshh that aint nothing, you should see the horrible cars we getting coming into my work all day, whenever you get the car running just let the motor idle with 4 quarts of automatic transmission fluid instead of oil. leave it running for about 30 minutes and let it drain, repeat a few times and install your new motor oil, after that replace your oil every 3k miles and be done with it. </TD></TR></TABLE>
Will ATF really clean the motor without ******* it up???
I'm planning to do some cleaning and I was thinking of running my oil for 3000 miles, and then right before the change to drain 2 quarts and top it with the ATF and let the car idle for some time...
Then drain it all out and replace the filter and new oil... will it work...
Can anything bad happen to the engine?
Will there be any left-offs of the ATF fluid in the engine after draining that can hurt the car (cos I know that there is always some amount of oil in the head...
Which is the PROPER way to clean with ATF?
Old Aug 28, 2004 | 03:38 AM
wHOAlly's Avatar
Default Re: What do you guys think? oil Prob perhaps? (KKVTi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KKVTi &raquo;</TD></TR><TR><TD CLASS="quote">
Which is the PROPER way to clean with ATF?</TD></TR></TABLE>
just do it the right way and read what we said above...
http://auto-rx.com/
Old Aug 28, 2004 | 05:32 AM
Well I gues I will never use penzoil. EVER and I will tell people to stay clear of it. I am going to run a little engine cleaner in it after its in my car.
Thank you all for your help and insight.
Moral of story dont use penzoil. At all.
Old Mar 13, 2005 | 08:20 PM
mumser101's Avatar
Go to this site, http://www.rms13.com and see what Auto-Rx did on an engine that was in a lot worse shape than yours.
Old Mar 13, 2005 | 08:34 PM
Ajax's Avatar
Default Re: What do you guys think? oil Prob perhaps? (mumser101)
I think it was Pennzoil that was used it my 80 Impala. Think thats bad? I had clumps of sludge under my valve covers. Not just a little here and there, I had big ******* clumps. I also had about 1/8th inch of **** stuck to the top of my valve covers. It looked like someone tried to rino-line my engine.
Old Mar 13, 2005 | 08:35 PM
PURPLETERROR aka BIGMATT's Avatar
change the oil, and add half a can of sea foam and drive it, rinse and repeat
