got some questions on using a 99+ JDM ITR/CTR ECU on a 2000 civic SI
Old Aug 26, 2004 | 08:17 PM
JDMvtecDRAGSTA's Avatar
Default got some questions on using a 99+ JDM ITR/CTR ECU on a 2000 civic SI
well i know the 2000 civic SI ECU is ran on a p2t ECU stock.
i really wanna take out the secondary o2 sensor on the motor
my question is would using a 99 and up ITR/CTR ECU remove the secondary o2 sensor.
kinda hard to explain but i know that the JDM motors are ran only on one o2 sensor so the ECU should work right? cause i put on a JDM ITR header on my friends SI and now it throws the code for the secondary o2 sensor and it really bugs so we wanna remove it.
sorry but i only have experience with obd1 setups rather than obd2
thanks
Old Aug 27, 2004 | 05:33 AM
All-MotorSports's Avatar
Default Re: got some questions on using a 99+ JDM ITR/CTR ECU on a 2000 civic SI (JDMvtecDRAGSTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMvtecDRAGSTA &raquo;</TD></TR><TR><TD CLASS="quote">my question is would using a 99 and up ITR/CTR ECU remove the secondary o2 sensor.</TD></TR></TABLE>
Yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMvtecDRAGSTA &raquo;</TD></TR><TR><TD CLASS="quote">kinda hard to explain but i know that the JDM motors are ran only on one o2 sensor so the ECU should work right? cause i put on a JDM ITR header on my friends SI and now it throws the code for the secondary o2 sensor and it really bugs so we wanna remove it.</TD></TR></TABLE>
Yes, the ECU will work, but you're going to need an OBD2b -&gt; OBD2a jumper harness if you don't want a major wiring headache. The 99-00 Si wiring harness has OBD2b plugs on it and the 99+ P73 ECU accepts only OBD2a plugs. E-mail katman@ff-squad.com for more info. on the jumper harness.
jchrm80
10
Jan 25, 2007 09:00 PM
dragnsi
Jan 19, 2005 05:32 AM
unstopabledj
Jul 28, 2004 09:26 PM
96_GsR_BlownEngine
Jul 24, 2004 04:03 PM
NH88TSI
Feb 7, 2004 08:59 AM
