89 Integra????
Old Aug 26, 2004 | 03:18 PM
White86CRXSi's Avatar
Default 89 Integra????
In one of the local junkyard i found an 89 integra not sure about gsr and all that crap cause the emblems are gone but i popped the hood and to my suprise i seen the beast of a motor that appears to be in it, to my suprise i peered inside an seen a 7 grand redline, what kind of motor is this and will it fit into my car easily its one of the ones with a black valve covers where the sparkplugs are in the middle of the valve cover and deep within and its dohc.. any help greatly appreciated...
Old Aug 26, 2004 | 03:44 PM
EL Vap133's Avatar
Default Re: 89 Integra???? (White86CRXSi)
The GSR didn't come out until 92 I believe.
Old Aug 26, 2004 | 03:46 PM
Default Re: 89 Integra???? (EL Vap133)
Well could it possibly be a ZC?
Old Aug 26, 2004 | 03:52 PM
t0eKnEe's Avatar
Motor is a D16A1 which puts out 118hp. And it wont bolt up to an 88-91 civic/crx.
Old Aug 26, 2004 | 04:01 PM
Default Re: 89 Integra???? (t0eKnEe)
so what car do i look for in a junkyard that would contain a b16 or a zc?
Old Aug 26, 2004 | 04:25 PM
t0eKnEe's Avatar
If you have an 86 crx si then that 89 integra motor will be your best bet. Thats the only motor I believe that bolts up to your car.
Old Aug 26, 2004 | 04:36 PM
how much bigger of a difference in power will this make and can you tell me what other parts i will need.. it will bolt directly to the mounts that i have already will i have to order a mount kit, a different ecu... all that good stuff if possible can you please list what i will need?
Old Aug 26, 2004 | 04:46 PM
Fleas_Ef's Avatar
u wont find to many b16's at the junk yard and if u do they wont be cheap
Old Aug 26, 2004 | 04:56 PM
t0eKnEe's Avatar
Default Re: 89 Integra???? (Fleas_EF)
The 1986-1989 Integra DOHC D16 engine and transmission will bolt right into a 1st Gen CRX. At the top of the family tree for the D Series, DOHC 1600cc, 16-valve engine is the JDM spec ZC engine of 135 hp. Next in line was the Euro-spec D16A8 which makes about 120 hp. In the US, we got the D16A1 Black Valve Cover version in the 1988-89 Integra, with 118 hp. And at the end of the line is the D16A1 Brown Valve Cover version in the 1986-87 Integra with 113hp. Many people refer to all 1986-89 Integra engines as being a ZC, but this is not technically correct. ZC is Honda's term for the top rated version of any family of engines. Not many people realize that there was a ZC version of the SOHC D16 engine that was sold in Japan. If you can find all of the JDM parts, you could build a USDM D16 into a ZC. But those parts are rare and probably expensive. The Brown and Black valve cover version of the DOHC D16 engine are very easy to install. The 88-89 Integra engine (black valve cover) is slightly more powerful than the 86-87 engines (brown valve cover) because it has a better flowing intake manifold, domed pistons with higher compression and lighter connecting rods. The black top D16 has a very different distributor and ECU that will not “just plug-in” to a 1st Gen CRX. You CAN NOT use the brown top distributor on the black top engine. The BROWN Valve cover is equipped with: -Flat top pistons -Thicker rods -Square styled intake manifold -Vacuum advance ignition with external coil The BLACK Valve cover is equipped with: -Domed pistons -Slightly lighter rods -Rounded intake manifold. -Electronic advance distributor with internal coil. ACTUAL SWAP INFO: Engine Mounts (total of 3 mounts on 84-87 Civic/CRX's): Use the stock Civic/CRX mounts on the rear cross member & front timing-belt side. Use an 86-89 Integra tranny mount for the tranny. The Civic/CRX tranny mount will make the motor sit crooked if you use it, so don't. Axles: Use a complete set of 86-89 Integra axles including the intermediate shaft. Knuckle/hub assembly: In order to use an 86-89 Teg' engine + transmission, you have to use the 86-89 Integra knuckle/spindle assembly so that you can utilize the Integra 3-piece axles. The 86-89 Integra axles DO NOT plug into 84-87 Civic/CRX knuckle/spindle's. Shift linkage: Use a complete 86-89 Integra's shift linkage. Wiring harness: Use the 1st Gen CRX Si's wiring harness. Plugs right into the 86-87 Integra sensors, injectors, & distributor. Distributor & ECU: Make sure you use an 86-87 Integra ECU & Distributor. That's the only DOHC ECU (besides a JDM one) designed to work with a Vacuum Advance Ignition (distributor), which only came on the 86-87 Integra's. ***Do not use an 88-89 Teg' ECU or Distributor**** Simply because it has an internal coil ignition just like all the 88+ civic/CRX/Integra use, which is completely different than the 86-87 ignition components.
Old Aug 26, 2004 | 05:01 PM
t0eKnEe's Avatar
thats one big *** paragraph, BTW, I got that pizzaragraf from http://www.redpepperracing.com...al=28
Old Aug 27, 2004 | 06:57 AM
thanks, i offer him 200 for it today and see what happens
FrankencrxBHAM
Nov 19, 2004 09:42 AM
93slmdcvcsi
Mar 26, 2003 01:15 PM
jester
Jan 23, 2003 05:41 PM
tdc
Feb 9, 2002 05:28 PM
A
Nov 30, 2001 06:41 AM
