Leaking coolant from intake mani
Old Aug 26, 2004 | 11:09 AM
EF4lyfe's Avatar
Default Leaking coolant from intake mani
I put a d15b into my car, havent started it yet, but im getting a coolant leak from the intake manifold, the leak is coming from the back side facing the firewall, its coming from a bolt, the lower bolt of the two, it is tightened as tight as it can go, what should i do?
Old Aug 26, 2004 | 11:40 AM
1SIKCRX's Avatar
take the intake manifold off. and put a new IM gasket on.
Old Aug 26, 2004 | 11:43 AM
EF4lyfe's Avatar
im=intake mani? correct?
Old Aug 26, 2004 | 11:51 AM
EF4lyfe's Avatar
why would a bad intake mani gasket cause a leak from a screw in the back side of it to leak, is that possible?
Old Aug 26, 2004 | 12:02 PM
EF4lyfe's Avatar
bump, sorry its important need car asap
Old Aug 26, 2004 | 12:11 PM
EP3_05's Avatar
Default Re: (SIhatch90)
Are you talking about one of the mounting studs with a nut on the end? If so the gasket goes over these and if it has rotted out and cracked it will not seal around the coolant passages and the fluid gets into the cracks and looks for a way out. It found a way out at that bolt location. I would replace the gasket. Also check all the coolant hoses to make sure they are soft and not dry rotted.
Old Aug 26, 2004 | 01:25 PM
Tyson's Avatar
Default Re: Leaking coolant from intake mani (SIhatch90)
are you talking about the IACV on the backside of the manifold near the throttle body? theres special rubber o ring sandwiched in there. probably need to replace that, or seal it up with some liquid gasket.
Old Aug 26, 2004 | 02:37 PM
MatHadder's Avatar
Is it just leaking a little, or is it just pouring out?
Old Aug 26, 2004 | 07:23 PM
1SIKCRX's Avatar
yes, IM=Intake Manifold
Old Aug 26, 2004 | 07:57 PM
crxdx89's Avatar
get a new gasket. it could also be leaking out of the water passage on the intake manifold too. thats what happened to me, a lil liquid gasket and alllll better.
Old Aug 26, 2004 | 08:02 PM
krazie1's Avatar
BANNED
Default Re: (crxdx89)
that is a trip u leaking w/o turning the engine on???
but sure is the gasket easy to fix in like seconds when u remove the IM
Old Aug 27, 2004 | 12:23 PM
EF4lyfe's Avatar
yea it definetly sucks that it is leaking already
, hopefully i have some better luck when it finally going
Apex1972
Mar 11, 2010 11:14 AM
cleanazcoupe
Nov 9, 2008 08:11 PM
chu77
Jul 25, 2006 05:03 AM
Jeffrey9
Nov 27, 2005 12:25 PM
Jowee
Nov 18, 2005 10:07 AM
