Which ECU for my DOHC ZC swap?
wondering if i should keep the stock ECU from my '94 hatch when i swap my ZC or get a pg7 to put in it. the car is an automatic so i don't know if the higher reving would even matter.
not tryin to flame you,but why would you put zc in a 94?for the money you spend on the zc,i would put new pistons on the block,and built the head.you would probably be putting dow 140whp.
ZC is not a bad motor!! so shut it!!!
If its a 94 you need to run an OBD1 P06 with a chip to raise the rev limiter.....
I have DOHC ZC in my 92 EG.....I'm running a p06 chipped with 7500 revlmiter....with a base map of a p29 (DOHC ZC OEN ECU) and I run great......when I had my p06 with a fukked up chip, I dyno'd 123whp/106lbs......this is with i/h/e......some tuning etc I should be near 130whp/112lbs....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">ZC is not a bad motor!! so shut it!!!
I have DOHC ZC in my 92 EG.....I'm running a p06 chipped with 7500 revlmiter....with a base map of a p29 (DOHC ZC OEN ECU) and I run great......when I had my p06 with a fukked up chip, I dyno'd 123whp/106lbs......this is with i/h/e......some tuning etc I should be near 130whp/112lbs....</TD></TR></TABLE>
it's not a bad motor for an ef
i just dont think they are worth it in a 92-95,unless ofcourse you had the d15 non vtec...
Most would say that, but it has more tuning capabilites than a z6 imo.....
and they loooove boost......mines OBD1 STOCK outta the 91 EG5............so it was drop in got it for under 1k installed with tons a new **** in the bay....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">actual ECU for the OBDI ZC DOHC is P29...
btw. I have one for sale (only $80US shipped - this is a 5spd version) shamless plug
Good deal from a good seller guys.
</TD></TR></TABLE>Good deal from a good seller guys.
damn where were you when I needed one!! hahahahaha
p29 is good, but from what I heard you can tune it alot and get better results.....
Thats why I went with the p06 with chip.....
LorenGeist
Aug 14, 2004 03:01 PM
