our H22a all motor dyno
Bone stock internals
skunk2 i/m
AEM ITR intake
An-r header
act clutch and fly
hondata s100
190whp/145 tq
http://www.imagestation.com/pi...2.jpg
then with 100 shot direct port(tuned pig rich)305 whp/256 tq
http://www.imagestation.com/pi...5.jpg
skunk2 i/m
AEM ITR intake
An-r header
act clutch and fly
hondata s100
190whp/145 tq
good numbers, but you can get more out of it......this is what we had...
AEM intake
DC header
FPR
apex exhuast
rz clutch and fly
ECU RomTuned
crower cams and valve train(stock non ported head)
Stock bottom end
195whp/150 tq
keep at it, you should see over 200 for sure
AEM intake
DC header
FPR
apex exhuast
rz clutch and fly
ECU RomTuned
Stock bottom end
195whp/150 tq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeSH »</TD></TR><TR><TD CLASS="quote">^^ hows that? he doesnt even have cams and is making as much power as you are.</TD></TR></TABLE>
thats what i ment.....if we did it with just cams and thats the only thing he has not done yet then he could see over 200 for sure if he upgraded, thats all......just giving the guy some info he could use and letting him know what we used for cams to get the power we did.
Are you using a hondata gasket with the skunk IM? I believe you can get a little more out of it also. Awesome numbers nonetheless.
One last thing what was the Air fuel ratio?
The all motor run doesn't look tuned very well. You'll defintely see more out of it if you spend time tuning the all motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedZone »</TD></TR><TR><TD CLASS="quote">
thats what i ment.....if we did it with just cams and thats the only thing he has not done yet then he could see over 200 for sure if he upgraded, thats all......just giving the guy some info he could use and letting him know what we used for cams to get the power we did.</TD></TR></TABLE>
My bad...Early morning wasnt really thinking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]The all motor run doesn't look tuned very well. You'll defintely see more out of it if you spend time tuning the all motor.</TD></TR></TABLE>
I agree...but nice numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD »</TD></TR><TR><TD CLASS="quote">]The all motor run doesn't look tuned very well. You'll defintely see more out of it if you spend time tuning the all motor.</TD></TR></TABLE>I agree...but nice numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmay »</TD></TR><TR><TD CLASS="quote">the a/f all motor was 12 all the way across, i dont know why the graph goes like that.</TD></TR></TABLE>
12 is too rich
12 is too rich
12 is too rich</TD></TR></TABLE>
thats ok, we like it safe
Not trying to step on your toes or anything, but too rich is just as detrimental, while you may not lean out w/ 12 there are many other reasons not to be so rich.
13:1 is more than safe and will net you better power.
EDIT: This is speaking all motor of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridewhencan »</TD></TR><TR><TD CLASS="quote">Why do you have the nitrous come on so late? Why not 3500?</TD></TR></TABLE>
we dont want to spray in 1st gear with drag radials
its comes on at 40mph, has to be 80% throttle and above 3500 rpms and shuts off at 7700
Nice. What kind of controller? I have mine come on at 3500 and shut off at 7400 (fuel shut off is set at 7600.) I have only a WOT switch but would love to have a speed sensitive control. I can't launch worth sh*t. I leave it off in first and then mess myself up by having to switch it on in second. Only alternative is to try not to go WOT in first and that's not too satisfactory either.
TracerAcer2.2L
Mar 23, 2015 06:20 PM
