my car is not running correctly! can someone help me out!!??
Old Aug 25, 2004 | 05:51 PM
DualCamEK's Avatar
Default my car is not running correctly! can someone help me out!!??
alright! so i set up and installed my turbo this week and a few things are going wrong... for one i dont think my car is going into full boost...i know it is boosting some because the wastegate and blow off valve are releasing pressure... 2nd, it is cutting out or detonating around 5k... my motor is a stock d16y7 with t3/t04e turbo. i start boosting around 3700ish. ive checked all vacuums no leaks.. no piping leaks... it appears that the turbo inlet stops spinning every now and then at idle. if someone how any idea please tell me some info!! i would greatly appriciate it! i also have a 12:1 fmu 255 fuel pump.
Old Aug 25, 2004 | 06:37 PM
Sunrise City Rider's Avatar
Default Re: my car is not running correctly! can someone help me out!!?? (jdmjoe949)
Change your spark plugs, distributor cap, rotor, and wires...Check your timing with a gun and back it off 2 degrees from whatever the Y7motor reccomends...Change your fuel filter as well...
Your turbo doesn't have to spin at idle...
Old Aug 25, 2004 | 08:36 PM
DualCamEK's Avatar
Default Re: my car is not running correctly! can someone help me out!!?? (Sunrise City Rider)
any other suggestions... thank you for your reply!
richieb18c1
Aug 16, 2008 09:02 PM
antballs420
Dec 31, 2005 12:56 AM
stockegsix
Apr 30, 2003 11:42 PM
stockegsix
Apr 27, 2003 10:26 PM
sushibug
Jun 29, 2002 04:59 PM
