What would be an ideal Clutch and Flywheel setup for 185-200hp?
I have a 1996 b18c1 planning to put out about 185-200whp. What would be a good/daily driveable clutch and flywheel setup? Thanks for your input H-T!
Check out action clutches. You dont need a crazy stage 75 or whatever to put the power down. Go with one that holds the power and is easy to drive. An ACT street lite 12lb would be a good flywheel choice.
I run clutch master light weight aluminum flywheel and stage 4 clutch. This is a great clutch and company. They are always very informative and are willing to help out. I haven't really had any major issues with them.
Search this back a couple of months, there were several threads debating the best clutch for sveral similar setups...Exedy, CM, ACT, and Action were among the most popular..........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown »</TD></TR><TR><TD CLASS="quote">Check out action clutches. You dont need a crazy stage 75 or whatever to put the power down. Go with one that holds the power and is easy to drive. An ACT street lite 12lb would be a good flywheel choice.</TD></TR></TABLE>
glad someone else is smart enough to realize that you don't need a full race clutch for a gsr with bolt ons.
See if you can talk to some people with aftermarket clutches and ask them to try them out or something. Find something you like.
for 185/200whp My set-up is wonderfull, my opinion
its the Exedy organic clutch with a spoon flywheel. No stiff pedal feel and has lasted me for 2 yrs now, daily driven and weekend road race and it's still going with no slippage.
thanks for the input so far everyone! I might just go with a ACT six puck...what would be better for a daily driver...prolite or streetlite? I'm still debating on whether or not I want a lightweight flywheel...
also, do aftermarket flywheels last pretty long? I dont want to have to replace the flywheel down the road anytime soon...
i got the prolite
not not tht bad. feels just like my old car. it dose get jerkey at times but i can live with it.
i was really scared about it but its not as bad as i thought it would be.
dude, just get your stock flywheel lightened and balanced and go with a clutchmasters stage 3 clutch. i have that setup and its flawless (maybe even on the grabby side)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22A-AllMotor »</TD></TR><TR><TD CLASS="quote">Pro-light 9lb. flywheel.
ACT Puck-six stage2 or stage3 clutch, either one is suitbale for 185-200hp. </TD></TR></TABLE>
ain't the 9lbs sometime cause idling problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeegsr »</TD></TR><TR><TD CLASS="quote">
ain't the 9lbs sometime cause idling problem?</TD></TR></TABLE>
I've got a CM 9lb flywheel, and I never had any idling problems.......
I've been using the stock OEM ITR clutch for almost 1 year or a bit longer. I hate stiffy pedal feel for a daily driven car!!!
not to steal the thread but i was wondering if a CM stage 3 or 4 would be a good choice for me cuzthe place were im getting them from have both stage 3 and 4 at the same price of 459 with free shipping..my set up is all motor ls..stage 3 pnp head..404s..TI retainers..SS valves..dual valve springs...n im about to put sum CTR pistons in there to to boost ^ the compression and ill be taking this up to 8500-9000..9500 if i have to
Get an action 1ks! The clutch is awesome! Definately streetable, and it is more durable than some of the other clutch brands out there. I have driven in cars which had clutch masters, and exedy clutches, and my friends and I prefer my clutch so much more.
Action 1 KS
Action 1 KS
