Pos and Neg battery wire
Had my check engine light come on last week. Long story, here goes:
Had a full exhaust put on about a month ago. Did the the header swap myself due to local regulations. Now on the o2 sensor i had to cut the wires and use an impact driver to break the sucker loose not knowing they made a sensor socket. Spliced the wires back together/ not soldered/ installed and ran fine for the time being. No light or any problem. Car last week started acting funny on the road. No check light, but would run at rpm with the gas all the way to the floor with no rpm gain, then would recover like nothing was wrong. This problem was very random. 1st idea was the o2 sensor so i started talking to people and they are saying the car should run without the sensor, but like ****. Pulled it, light came on, ran at idle then did a rpm drop, recovered, idle to a drop and die. Replaced the sensor, pulled the POS battery cable and main relay fuse/ 7.5amp/ and still nothing. Have pulled the cap, wires, plugs, etc OK.
Now with my searching everyone list the NEG wire to be pulled. Whats the difference?? I know everyone is going to say check the code, but the car for 4 year has never had any problem till this / self induced. Scheduled for a tow and check at the shop tomorrow but would like some input. Thanks Todd
Modified by toadolson at 6:31 PM 8/25/2004
Captain_Fook
Apr 10, 2014 03:24 PM
adamisgreat88
35
Jun 18, 2009 12:25 PM
Rebuilt D16Y8
Nov 28, 2005 04:59 PM
slackeR1366
Jun 21, 2001 03:12 PM
