need to change my 6th gen accord alternator !!!
hi guys i have loud system more than 120 amper current flow and the alternator can't i guess can't take that.
i have yellow top Optima. i don't know how much my alternator but.
i have done the Big 3.
so which alternator can fit ?? can i use GM motor alternator ?? is that safe ?
i have heard High output alternator = low hourse power !!
is that true ?
thanks
is that true ?
thanks
That's not really true. You might get more help in the audio section but I'll tell you this real quick. The cap doesn't just zap power from your alternator to fill up when it is empty. The cap is always feeding off of the alternator. Then when it gets a little used it just slowly saps some more. It's not an instant yank of all the power. Caps work very well and you really should get one.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2290 »</TD></TR><TR><TD CLASS="quote">That's not really true. You might get more help in the audio section but I'll tell you this real quick. The cap doesn't just zap power from your alternator to fill up when it is empty. The cap is always feeding off of the alternator. Then when it gets a little used it just slowly saps some more. It's not an instant yank of all the power. Caps work very well and you really should get one.</TD></TR></TABLE>
what he said
what he said
well i don't know may be u are right. i studied electronics but i really forget how do they works.
any way i still think i am don't need a can at least i am a competitor or somthing with huge power , i think my yellow top can feed what i need very fast the only problem is when the car is working my alternator need to be changed.
check here :
http://forum.sounddomain.com/f...00000
thanks guys .....
check here :
thanks guys .....
4gen
Audio / Security / Video
May 28, 2004 03:33 PM
kris10renee
Jan 23, 2003 09:11 PM
