H22A N/A engine building
Old Aug 25, 2004 | 12:54 PM
CrAzYNeSs's Avatar
Default H22A N/A engine building
Sup everyone, im new to this forum and wanted to say hi n ask for your experties. After a long time of debating weather to go turbo/super/na i've decided to build my engine N/A style.. even tho it cost more i think n/a is sexy...
I have a 1999 Honda Prelude w/ the standard mods: AEM I/ DC stainless H/ E
I also have parts that are waiting to be installed:
Skunk2 Stage 2 Camshaft
Skunk2 Camgears
Skunk2 Intake/Exhaust Valve
Skunk2 Springs and Retainers
Exedy Stage2 Full face race clutch
My questions are as follows...
1) do i need to get my car tuned or can i run it w/ these parts installed untuned w/o killing my engine...?
1a) if i need it tuned.. do i need to get hondata or vafc? if so which one is sufficient enuf for my car w/o spending a crap load of money
2) lastly, do i need bigger fuel injectors with these mods?
thanks alot
-jeff
Old Aug 25, 2004 | 07:28 PM
ranta18's Avatar
Default Re: H22A N/A engine building (crazychomp)
1) YES!
1a) V-AFC will work, but Hondata would be best
2) No
Old Aug 25, 2004 | 07:31 PM
Rick Solis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazychomp &raquo;</TD></TR><TR><TD CLASS="quote">1) do i need to get my car tuned or can i run it w/ these parts installed untuned w/o killing my engine...?</TD></TR></TABLE>
Yes, tuning is highly recomended...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazychomp &raquo;</TD></TR><TR><TD CLASS="quote">1a) if i need it tuned.. do i need to get hondata or vafc? if so which one is sufficient enuf for my car w/o spending a crap load of money</TD></TR></TABLE>
VAFC will work, but Hondata is recomended...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazychomp &raquo;</TD></TR><TR><TD CLASS="quote">2) lastly, do i need bigger fuel injectors with these mods?</TD></TR></TABLE>
I would...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazychomp &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot</TD></TR></TABLE>
Your welcome...
Old Aug 26, 2004 | 04:39 AM
ranta18's Avatar
Default Re: H22A N/A engine building (Rick Solis)
With my Crower Stage 2's making 209 whp tuned with a V-AFC I didn't have to add more than 5% fuel at any point. I think it ranged from -5% up to 5% from 4000-8000 rpm. Mainly around the VTEC crossover it would get lean, so I had to add fuel.
Old Aug 26, 2004 | 05:25 AM
94gsrsedan's Avatar
I THINK IM GO ALL MOTOR WITH MY HATCH
Old Aug 26, 2004 | 07:45 AM
ranta18's Avatar
Default Re: (94gsrsedan)
SWEET!
Old Aug 26, 2004 | 10:10 AM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazychomp &raquo;</TD></TR><TR><TD CLASS="quote">Sup everyone, im new to this forum and wanted to say hi n ask for your experties. After a long time of debating weather to go turbo/super/na i've decided to build my engine N/A style.. even tho it cost more i think n/a is sexy...
Skunk2 Camgears
thanks alot
-jeff</TD></TR></TABLE>
Did I read the site wrong or doesn't Skunk2 say not to use their valves when you go Stage2+?
Old Aug 26, 2004 | 11:55 AM
ranta18's Avatar
Default Re: H22A N/A engine building (DarkKnight[DMD])
Skunk2's website - "Oversized valves should not be used with standard size valve seats or with Stage II and III VTEC camshafts."
So as long as they are the STD size valves, he's ok.
Old Aug 26, 2004 | 12:16 PM
Rembrandt's Avatar
Default Re: H22A N/A engine building (ranta18)
What is the stroke length of the H22?
Isn't the H23 95mm?
I've seen a few dyno graphs and many don't go far past 8000rpm.
Old Aug 26, 2004 | 12:40 PM
96redgsr's Avatar
ive heard that skunk valves bend easily, and i was told by my mechanic to stick with oem valves and just replace the valve seals when getting all the valvetrain and cams put in, but again, thats just what ive HEARD.
Old Aug 26, 2004 | 12:46 PM
ranta18's Avatar
Default Re: H22A N/A engine building (Rembrandt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rembrandt &raquo;</TD></TR><TR><TD CLASS="quote">What is the stroke length of the H22?
Isn't the H23 95mm?
I've seen a few dyno graphs and many don't go far past 8000rpm.</TD></TR></TABLE>
H22 is 90.7mm. Most people don't go past that because their cams don't make power past that or they are either scared of the piston speeds. I plan on making power to 9000 with my new setup.
hingi
Mar 24, 2010 10:43 PM
commando150
Nov 17, 2007 01:12 PM
CrAzYNeSs
Aug 25, 2004 01:50 PM
Dave01
Feb 22, 2004 03:16 PM
