Questions about my 1990 Civic Si all original parts
Old Aug 25, 2004 | 12:09 PM
Ralpho's Avatar
Default Questions about my 1990 Civic Si all original parts
Can someone give me a complete rundown
motor name, chassis code etc...
I'm getting conflicting info
108 HP at 6200 RPM
100 lbs at 5000 RPM
any help would be great, I posted this in the EK+/ DEl SOL forum accidently and some jerk from pa gave me the business. Not a nice way to start out on this site.
I'm all posted out, I reached my 5 post limit thanks a lot though
Modified by Ralpho at 1:25 PM 8/25/2004
Old Aug 25, 2004 | 12:14 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
It's the ED9, D16A6 engine, 108 Hp.
You've got it right.
Look around, and for God's sake, stay in here, we're much nicer.
I owned 2 90 Si's myself, 1 civic, and 1 CRX.
Let us know if you wanted anything else specifically.
Old Aug 27, 2004 | 09:25 AM
Ralpho's Avatar
Default Re: (VashTheStampede)
Thanks again you wouldn't happen to know the weight of the car, the door jam sticker is a bit faded, also what is the stock tire pressure front and rear, the wheels are 14" with 205 65's i think, thanks again.
Old Aug 27, 2004 | 09:41 AM
crxgator's Avatar
Default Re: (Ralpho)
weight is about 2200lbs, i hope your tires arent 205/65/14, you must be rubbing like crazy...stock tire size is 185/60/14 for the civic si...and usually 32psi for tire pressure...
Old Aug 27, 2004 | 10:17 AM
Targa250R's Avatar
be professional
You'll find that the EF forum is much more pleasant and helpful than the EG forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede &raquo;</TD></TR><TR><TD CLASS="quote">It's the ED9</TD></TR></TABLE>
ED9 is the CRX Si.
The Civic Si is ED7.
Old Aug 27, 2004 | 10:30 AM
APEX CRX's Avatar
Default Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">You'll find that the EF forum is much more pleasant and helpful than the EG forum.
yeah EG guys have issues
Old Aug 27, 2004 | 10:31 AM
crxgator's Avatar
Default Re: (APEX CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX &raquo;</TD></TR><TR><TD CLASS="quote">
yeah EG guys have issues</TD></TR></TABLE>
what do you expect from a bunch of stunnas y0!!1!
Old Aug 27, 2004 | 10:56 AM
Ralpho's Avatar
Default Re:
ED7 it is thanks, so what is the first thing I should do mod wise, it still has the factory airbox, intake? its got some cheesy arospeed exhaust, doesn't sound too bad I believe the ignition wires are 8mm, they seem fairly new.
I'm up for suggestions, plus I need a way to stop rust from spreading or at least slow it down, and I do not have a time machine so thats out of the question.
Old Aug 27, 2004 | 10:59 AM
hatchinprogress's Avatar
ED9 is the CRX Si.
The Civic Si is ED7.</TD></TR></TABLE> i guess thats another reason to go the ef route x2
Old Aug 27, 2004 | 11:06 AM
Ralpho's Avatar
Default Re: (hatchinprogress)
will a VTEC controller work on a 90 civic si?
can anyone for the life of me tell me how Mugen is pronounced properly?
phonetic spelling if you please
Old Aug 27, 2004 | 11:25 AM
yellowcrx1991's Avatar
Mugen is pronounced Moogen, oh at least thats the way I say it.
As for a VTEC controller, its not needed on a stock Civic Si motor, our engines didn't have VTEC.
Old Aug 27, 2004 | 11:27 AM
Targa250R's Avatar
be professional
Default Re: Re: (Ralpho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ralpho &raquo;</TD></TR><TR><TD CLASS="quote">ED7 it is thanks, so what is the first thing I should do mod wise, it still has the factory airbox, intake?</TD></TR></TABLE>
For 4th-gen Civics, simply removing the resonator box will free up the intake at no cost. Remove the "snorkel" piece that goes up over the exhaust, just behind the radiator, then remove the "Y" piece that enters the bottom of the airbox. Then, take off your front bumper and unbolt the plastic resonator box. Reinstall the bumper and you're done. A new K&N drop-in air filter is a good idea.
An aftermarket intake will help, but I personally believe that they do not provide enough gain for the money on a relatively stock D16A6. Others' opinions may vary. If you can pick up an aftermarket intake on the cheap, then do it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">its got some cheesy arospeed exhaust, doesn't sound too bad I believe the ignition wires are 8mm, they seem fairly new.</TD></TR></TABLE>
The exhaust is probably just a muffler. To free up some power, eventually you may want to upgrade to a 2.25" mandrel-bent cat-back system with a free-flowing muffler (which muffler is usually personal preference). You'll probably also want to look into a high-flow catalytic convertor and an aftermarket header. You can learn more about exhaust setups for our cars by searching.
For plugs, use NGK or Denso. Use the spec that Honda recommends, unless you are boosting or using nitrous. Platinum plugs last longer than standard copper, but cost much more and should still be changed often, so I recommend to stick with regular copper plugs and chage them every 15,000 miles or so.
For plug wires, I suggest to use only OEM Honda (made by Sumitomo). Honda's ignition systems are some of the best OEM ignition systems out there, and are good up to about 400hp or more. Some of the fastest drag Civics out there are using completely stock ignition systems, with exception of the coil and plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm up for suggestions, plus I need a way to stop rust from spreading or at least slow it down, and I do not have a time machine so thats out of the question. </TD></TR></TABLE>
First, have any rust on your car's body removed and repaired. Then, squirt some oil around the inside of the rust-prone areas to keep the water away. Reapply often. Keep the exterior and the wheel wells free of filth and crud. Not driving the car in winter snow and salt will help considerably, but I understand that it is unavoidable if this is your only car.
There have been threads about rust prevention in the past, so a search should help you. I wish I could say there was a miracle fix, but there is not; it is the 4th-gen Civic's greatest enemy.
Of course, everything I post is JMO, and YMMV.
Old Aug 27, 2004 | 11:30 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ralpho &raquo;</TD></TR><TR><TD CLASS="quote">will a VTEC controller work on a 90 civic si?</TD></TR></TABLE>
No, because the D16A6 is not a VTEC engine.
VTEC controllers are used to adjust the VTEC engagement point when (dyno-)tuning a VTEC engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">can anyone for the life of me tell me how Mugen is pronounced properly?
phonetic spelling if you please </TD></TR></TABLE>
I've heard it pronounced several ways (I personally say "myoo-ghen" with a soft G sound). Call up King Motorsports and ask them for a definite answer
Tru3Hav3k
Sep 2, 2013 06:01 AM
PeIrMiPc
12
Mar 17, 2012 11:06 AM
Ecskater1313
Dec 2, 2005 06:26 PM
Scott_Tucker
Jul 9, 2005 01:26 PM
98typer794
Jun 19, 2003 11:50 PM
