What happens if you forgot O-ring on the center cam rail? What is the purpose? zero oil pressure...
Old Aug 25, 2004 | 11:10 AM
integmester's Avatar
Default What happens if you forgot O-ring on the center cam rail? What is the purpose? zero oil pressure...
Semi-built motor... b18c1 block, head, skunk 2 intake manifold, crower cams, unknown pistons, unknown valvetrains... i only got to drive it 700 miles after it was built.
My car is reading zero oil pressure after 700 miles of driving. So if i forgot the o-ring inbetween the center cam rail and head would it cause the oil light to go off? Someone has mentioned the o ring, but i don't clearly understand how it would make the oil light go off after so many miles of driving.
Could someone explain the purpose of the o-ring?
Old Aug 25, 2004 | 12:21 PM
chad174's Avatar
Default Re: What happens if you forgot O-ring on the center cam rail? What is the purpose? zero oil pressure
Vtec will not work without that o-ring and the dowel pin in there. It will not, however, cause your motor not to produce oil pressure.
EJ1_Can2
Oct 6, 2010 10:48 AM
stevenDAtegra
Jul 6, 2009 04:18 AM
THEDirtyDseriesWOOT
11
Jan 29, 2009 06:00 PM
BACKintheDA
Jul 12, 2005 01:05 PM
visual
Mar 23, 2003 02:41 PM
