Which cams would be better for a crvtec turbo setup?
Old Dec 4, 2001 | 05:59 AM
Mr.FBR's Avatar
Default Which cams would be better for a crvtec turbo setup?
GSR or ITR? I want to stay with stocks they cost way less for me...
Old Dec 4, 2001 | 09:00 AM
boosted hybrid's Avatar
Default Re: Which cams would be better for a crvtec turbo setup? (Mr.FBR)
Actually the b16a cams are better than the GSR cams, there is slight difference in the specs (not sure if it is lift or duration?) but they do give slight more power and are better for forced induction. The ITR would be the biggest cam that you would want to run, but they are really to much money that you could put else were in the engine like pistons, rods, intake manifold, etc. Probably look for a 10-15hp at the wheels spread over the entire rpm band with the ITR cams. Again if I were you I would run the b16a cams instead of the GSR cams, slight more power and you can get them cheap.
Old Dec 4, 2001 | 11:38 AM
Mr.FBR's Avatar
Default Re: Which cams would be better for a crvtec turbo setup? (boosted hybrid)
I have itr valves in the 99si head and new itr springs still in the package...should I run with GSR inner springs then. I could even keep the stock springs, they only have 19k on them.
I also have both 99-00 si cams or 90 jdm cams...which should I go with?
Help is greatly appreciated, I am still learning here...thanks
I should mention I can get them for a very inexpensive cost...
[Modified by Mr.FBR, 8:39 PM 12/4/2001]
Old Dec 4, 2001 | 07:28 PM
Mr.FBR's Avatar
anyone else...all info is greatly appreciated...
Old Dec 4, 2001 | 09:32 PM
BoostinDC2's Avatar
or just keep the ITR outers and run the port flow inners i hear that combo is similar to a JUN spring
[Modified by BoostinDC2, 6:32 AM 12/5/2001]
Old Dec 5, 2001 | 05:10 AM
1's Avatar
CTR in my CRVTEC turbo dynoed 3-4 p.s.i.= 224 w.h.p.
Will up the boost soon and post results.
Old Dec 6, 2001 | 06:51 AM
Mr.FBR's Avatar
Default Re: Which cams would be better for a crvtec turbo setup? (1)
anyone else?
Old Dec 6, 2001 | 01:04 PM
Dublocivic's Avatar
Im going to stick with my CTR's in my big boost Vortech project.. you just have to dial out some of the overlap with a good set of gears.
GSRintegra_Bob
Oct 10, 2005 09:49 AM
X2BOARD
Sep 16, 2004 11:06 AM
madman604
Nov 7, 2002 07:46 PM
hb_racer
Apr 18, 2002 04:23 PM
95vtec
Sep 30, 2001 11:13 AM
