car wont start! no spark?
Old Aug 25, 2004 | 10:46 AM
chitownrida's Avatar
Default car wont start! no spark?
sup guys, i pulled the h23 out to change the clutch/etc.. and wheni put it back in it wont start! all the grounds are hooked up, i the starter cranks strong. but there is no spark! i pulled the wire from the coil to the distribuitor and put it against a ground.. but no spark... any suggestions?? the car also was starting fine before the motor removal
Old Aug 25, 2004 | 10:54 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: car wont start! no spark? (chitownrida)
maybe your ignitor is bad, maybe your firing order is wrong (it should still spark though) external coil not hooked up properly.plugged into the wire harness. Did you change the timing belt? maybe your timing is off etc etc etc.
firing order is
34
12
Old Aug 25, 2004 | 11:04 AM
i dont figure ignitor, only because even the wire from the coil isnt sparking.. etc.. i didnt change the timing belt.. i had the motor out to change the clutch and install the drag gen 4 turbo kit. ..
Old Aug 25, 2004 | 11:20 AM
JTCdudeman's Avatar
Master H Technician
Default Re: (chitownrida)
well, sounds like your missing a ground if your not getting spark at all... Usually people miss the ground attached to the rear coolant connector(brain out of order) where the thermostat is.. its actually attached right under the vtec solenoid on h22, or under the intake cam for other reference.. It goes in the bolt and ground out there.. Thats typically the issue with that, or you dont have the coil connected.. ive seen both..
Old Aug 25, 2004 | 12:49 PM
ok, i will check that tonight. what ground wire goes to the thermostat housing?
because the battery ground.. is grounded to the radiator support and also under the starter
Old Aug 25, 2004 | 02:08 PM
98TypeSH's Avatar
Also, if you pull your battery and set it on the ground, thats a real good way to kill it.
Probably missed a ground. Did the same **** on my car, then sat and looked for about 10 seconds and found the bastard. Hope you find the problem
Old Sep 15, 2004 | 05:28 AM
this is going back up.. still no spark.. i replaced the ignitor with a brand new one.. still nothing. no spark
recap:
1. the car cranks fine ( starter works)
2. checked all the grounds.. (1 by trans, 1 to radiator support, 1 to side by valvecover,1 by thermostat housing)
3. the ignition coil shows 12v when i have the key to On position from top side of ignition coil
4. i have fuel pressure
Old Sep 15, 2004 | 03:10 PM
up.. i tried a new ignition coil. no help
Old Sep 15, 2004 | 04:32 PM
britishlude's Avatar
Just a shot in the dark but do you have an alarm anti theft device fitted that might need resetting now it's been re-connected ?
Old Sep 15, 2004 | 05:32 PM
no. no alarm on the car.. i'm totally out of options at this point
Philippines03j
Aug 24, 2021 08:26 PM
Afi Salevao
Feb 1, 2014 10:29 AM
delsolproblems
Aug 6, 2008 10:24 PM
lilmisshonda
Jul 1, 2008 07:06 PM
snakedoctor
Feb 14, 2006 07:47 AM
