missing throw out bearing in tranny?
Old Aug 25, 2004 | 10:10 AM
Vp Special K's Avatar
Default missing throw out bearing in tranny?
Is there anyway to check if the throw out bearing is installed without dropping the tranny? just swapped tranny back in and im not sure if i forgot the throw out bearing or not. Would a missing throwout bearing cause no presure in the clutch pedal even after trying to bleed it?
Old Aug 25, 2004 | 10:15 AM
nocturnaldragon's Avatar
Default Re: missing throw out bearing in tranny? (Vp Special K)
Yea because it gives the resistance needed for the clutch system, kinda hard to explain without showing you a picture. Anyhow im sure you put it in there, its difficult to leave it out, But to check remove the rubber boot that your slave cylinder goes into the bell housing. Now check your shift fork the Y side of it, should actually be inside the thowout bearing. The other end I would be the part pressing against the piston in the slave cylinder. Check your system for leaks tho propably near the Master Cylinder for the clutch assembly look in the car for leaks.......
Old Aug 25, 2004 | 10:51 AM
Default Re: missing throw out bearing in tranny? (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon &raquo;</TD></TR><TR><TD CLASS="quote">Yea because it gives the resistance needed for the clutch system, kinda hard to explain without showing you a picture. Anyhow im sure you put it in there, its difficult to leave it out, But to check remove the rubber boot that your slave cylinder goes into the bell housing. Now check your shift fork the Y side of it, should actually be inside the thowout bearing. The other end I would be the part pressing against the piston in the slave cylinder. Check your system for leaks tho propably near the Master Cylinder for the clutch assembly look in the car for leaks....... </TD></TR></TABLE>
good info, thanks for the help ill check them out
r.f.b
13
Nov 2, 2017 06:45 AM
garyhgaryh
Jul 21, 2007 03:05 PM
AFFIRMED
Aug 9, 2006 09:06 AM
Wheelman-CZ
10
May 27, 2006 11:50 AM
1fastdc2
May 13, 2006 05:10 AM
