Z10 Radius Bar Install Help
Old Dec 4, 2001 | 05:14 AM
sackdz's Avatar
Default Z10 Radius Bar Install Help
Finally got the bar in place after some quality time with the BFH. 5/6 bolts aint bad... I cross-threaded one in an attempt to pull the bar into place.
As for the center mount, I haven't drilled it yet, but it makes no sense to me. There are 3 holes in the center mount, but only the last hole fits under the rad support. I understand this bar fits more than one chassis, but the bolt they supplied was too big for the hole. In addition, if it did fit through, why a 4" bolt when it only has to secure to 3 layers of sheetmetal? Am I missing something here? Am I about to join the ranks of we-todd?
Here's a pic of my center mount, with a too long/too big bolt:
n/m i'll upload the pic later
[Modified by sackdz, 9:16 AM 12/4/2001]
Old Dec 4, 2001 | 05:31 AM
Dr Pooface's Avatar
Default Re: Z10 Radius Bar Install Help (sackdz)
This has been covered. The bolt they shipped is too long, just go buy a shorter one. While your at it replace the stripped bolt as well. Apparently you need to have all the bolts installed to enjoy the non wheel hopping goodness.
Old Dec 4, 2001 | 05:38 AM
sackdz's Avatar
Default Re: Z10 Radius Bar Install Help (Dr Pooface)
I read through all the threads, and some said the bolt was too long, and some said it worked. I just don't understand why they would include a bolt, regarless of length, that didn't fit in the first place. No one said anythign abou this.
And the threads in the frame are cross threaded, so I can't put it in. Well, I could try but the bolt would probably snap.
Old Dec 4, 2001 | 05:48 AM
Dr Pooface's Avatar
Get a tap and clean the threads up.
Old Dec 4, 2001 | 07:04 AM
Jason's Avatar
yeah, the bolt is too long...I'm pretty sure I covered this in one of my previous threads, as it was a problem w/ our install as well...
Old Dec 4, 2001 | 07:12 AM
sackdz's Avatar
I thought about it, but that would require removing th a/c, or at least some of the lines, to get to it.
My other option is to thread it in crossed, and just drive the f00ker in there, crossthreaded, but it would only hold up one time I think... and hopefully I'll never have to take off the bar.
Old Dec 4, 2001 | 08:07 AM
Dropspeed's Avatar
On the center Tab there are 3 holes, the one furthest from the motor, (out front )that is under the core support the bolt does not fit through. I just took the drill bit they recommended and drilled through the hole and through the core support and installed the bolt they sent.
Mattj
Old Dec 4, 2001 | 08:28 PM
Dr Pooface's Avatar
If you do that the bolt might break.
Old Dec 4, 2001 | 08:40 PM
nfn15037's Avatar
It would most definately snap. Just suck it up and do it the right way. Get a tap and clean up the threads. You are going to regret it later if you dont do it right this time.
Old Dec 5, 2001 | 11:23 AM
sackdz's Avatar
Default Re: Z10 Radius Bar Install Help (nfn15037)
Arg! Got one bar on, but the bolt on the fork on the drivers side would not come off with an impact wrench. Tried head, back and forth, nothing....
[ivi]
12
Apr 26, 2012 10:56 AM
mattsthru
15
Aug 18, 2007 01:24 AM
JDM.K20
Suspension & Brakes
13
Jun 16, 2007 06:22 PM
lude98SH
May 7, 2006 07:45 AM
the_illest_soldier
Jul 5, 2004 05:45 PM
