What do I need to install....
...a cusco front strut bar. Dont flame, but I have searched and I can not find what people used to install it. What size hole did people drill? What size bolt? I hear people saying to use a washer between the car and the bar. Also to use the biggest washer you in the fender area? If anyone knows please let me know.
Re: What do I need to install.... (EKcoupe99)
very simple, there are two little rubber peices, remove those, put a bolt going through the bar and frame, and then tighten a nut in the tire well.
Re: (_BEN_)
Thanks for the pic and info _BEN_
al3e...actually I believe 96-00 civics (besides 99-00 SI's) do not have a rubber piece covering the holes. They need to be drilled.
Location: Why so you can pretend like youre interested, FL/OK
Re: (JDMCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX »</TD></TR><TR><TD CLASS="quote">Man 4 8mm x 1.25 bolts drill 4 holes clean them with rubbing alchol and paint them let dry then use some antisieze and install them.
It will not rust and so forth.</TD></TR></TABLE>
I would most pay attention to this information. Good advice.
apalmucci
22
03-23-2011 01:36 AM
98civdx
Suspension & Brakes
05-15-2010 10:10 AM
