PRELUDE CLUTCH
i was driving down the road the other day. I pressed the clutch in. and it had a little more slack to it than usual. The clucth was engaging at the floor. had no pressure. the next day i went to crank it.. i pressed the clucth in and it hit the floor. no fluid. i guess. pumped it a few times got pressure in it. now i have none and cant get any back? any help?
Have a buddy press the clutch in while you look at the slave cylinder to see if it pushes in the clutch fork. From there check for fluid in the clutch container and check for leaks. Sounds to me like you slave or master cylinder is bad or you have a leak somewhere in the system.
Uh. The total cost was $239.96. That includes labor. The guy showed me.. Look where your slave cylinder is check for fluid around it.. then inside your car look up where you see the slave cylinder boot or w/e and see if there's any fluid there. If so.. thats bad. Then check your master cylinder. You should be able to pull the rubber back on the master cylinder and if you see any type of leak.. you know the problem. So to answer your question. Check ebay for a "new" slave cylinder. heh
good luck dude
good luck dude
whoever fixed your stuff... good mechanic (if it was one even) Showed you what was wrong and how to go about checking it.
There needs to be more people like that, not doing 1/2 crap jobs & giving the cars back to people without testing them. akdjflaksjdflaksfjdlkasdfj
sorry, had to let that out.
GraphiteMW
Mar 25, 2007 09:26 AM
JoJO...
10
Sep 30, 2005 08:56 AM
