!!Help!! May have blown either my tranny or clutch...(just happed 10 minutes ago)
Old Aug 24, 2004 | 11:12 PM
SuicideSlide's Avatar
Default !!Help!! May have blown either my tranny or clutch...(just happed 10 minutes ago)
So while in the middle of a speedshift I all of a sudden could not get it into gear. Then I had to match revs just to get my car into any gear so I could drive. At first the clutch pedal gave me a little bit of play, as I hit the clutch pedal (while in neutral) and tried to place the car into first it would grind as the gears came in contact with each other.
I decided to get the car to my shop. By the end of the drive, the clutch pedal now was impossible to even get any pedal movement. I can still match revs and blip the throttle to get it in gear. When the car is off the car shifts into the gears smoothly... Sorry this whole post seems garbled, its midnight, I have to be awake in 5 hours to go to work.
In short... do you guys think I grenaded my tranny or my clutch... thanks
Andrew
**EDIT**
And the pics of the outcome (CLUTCH BLEW)
Modified by Tur*bLu at 9:14 PM 9/24/2004
Old Aug 24, 2004 | 11:18 PM
gaydm.accord's Avatar
sounds like clutch pull your tranny bolt and see what comes out if you wanna make sure
Old Aug 24, 2004 | 11:54 PM
Stoich EG2's Avatar
check the master and slave cylinders (i doubt this is it but just to be safe)
Old Aug 25, 2004 | 12:30 AM
Steed77's Avatar
Default Re: (Advan06)
1 vote here for the clutch!
Old Aug 25, 2004 | 12:46 AM
tjohnson329's Avatar
Default Re: !!Help!! May have blown either my tranny or clutch...(just happed 10 minutes ago) (Tur*bLu)
it doesn't sound like the clutch to me maybe the throw out bearing is messed up or jammed or it could be your transmission. Sounds like the tranny syhcronizers arn't working to good. check both of them first.
Old Aug 25, 2004 | 01:34 AM
Syner-G-Racing LLC's Avatar
" I decided to get the car to my shop. By the end of the drive, the clutch pedal now was impossible to even get any pedal movement. "
If you cant move your clutch and its hydraulic...I would guess the lever for the clutch plate is bent or wedged possibly, as for the gears...Ive bent two shifting forks speed shifting. good luck
Old Aug 25, 2004 | 05:34 AM
EVILhatch's Avatar
its your clutch disc bro,i just had all that happen to me a few months ago,it sucked making the 12 mile trip home..
Old Aug 25, 2004 | 06:10 AM
B18C1 '96 Coupe's Avatar
Default Re: (EVILhatch)
Clutch maybe. WE need more info. Hydro or cable?
By brothers LS vtec wouldn't go into gear and I had to rev match putting it in. and the clutch pedal wasn't doing anything. I changed the fluid in the Clutch cylinder and what do you know it worked. start small. Even if the fluid didn't work . At least its all cleaned.
This is assuming you have a Hydro. On my 200sx Se-R When I broke the clutch disk. It would rev real high and not got in i wouldn't need to rev match. But when I broke the clutch fork. the pedal hit the ground and wouldn't come back up.
I am assuming you have hydro. So go and change the clutch fluid (using regulars brake fluid) and tell us how it went. I had to bleed the whole system. just changing the fluid will only put new fluid in. You want to press new fluid through the whole system.
Old Aug 25, 2004 | 06:44 AM
Default Re: (B18C1 '96 Coupe)
Ok guys Im at work now... Well we've got a busy day ahead of us at the shop so I may not beable to actually drop the tranny untill tomorrow afternoon. But I will go out and check my fluids. But I highly doubt its that simple.
I could literally be in 3rd or 4th gear and press the clutch in and it would barely release if at all into neutral. Would a bent shift fork mean a new tranny? Hopefully its just the clutch or something else.
BTW...I need to drop the shift linkage to drop the tranny correct?
Old Aug 25, 2004 | 07:15 AM
milton's Avatar
Default Re: (Tur*bLu)
its a clutch problem. your clutch is probably out. does it grab anymore? check fluids and any leaks..... more info would be helkpful
Old Aug 25, 2004 | 11:19 AM
regardless hydro or cable youll have to remove it from the tranny. if its cable swing it out of the way.
jrhcivak
17
Apr 11, 2012 03:55 PM
93JDMB18C
Apr 26, 2007 10:44 AM
slowdaintegra
Dec 21, 2005 01:31 PM
BoBo Racing
Nov 21, 2004 03:00 PM
green98civic
13
Jun 28, 2003 10:13 AM
