Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
autocross at hollywood park (rough lot) now strange sounds when moving
Old Aug 24, 2004 | 06:59 PM
duh blacksheep's Avatar
Default autocross at hollywood park (rough lot) now strange sounds when moving
car: greddy turboed gsr with an itr lsd. 400lb/in spring rate in front with 3/4 stiff on konis.
during the practice event, we broke hard and at the same time, hit an uneven patch (like pot hole, but square shape) on the surface and heard a really loud *thump* like a bottoming out sound. it happend twice. now the car has a weird clicking sound, it clicks faster as the car moves faster. and the car shakes back and forth (left to right) slightly. i checked where the axle connects to the tranny on the right side of the car, and i can move it in and out about .5 inches. is this normal, bad, or is the problem something else?
Old Aug 24, 2004 | 08:33 PM
farside's Avatar
Default Re: autocross at hollywood park (rough lot) now strange sounds when moving (duh blacksheep)
Take a look under the car. Maybe the axle popped out. Maybe you busted a bearing in the axle. If it is an axle, just get a new one from autozone.
Old Aug 25, 2004 | 11:01 AM
Default Re: autocross at hollywood park (farside)
bump
Old Aug 25, 2004 | 11:27 AM
kb58's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep &raquo;</TD></TR><TR><TD CLASS="quote">... i checked where the axle connects to the tranny on the right side of the car, and i can move it in and out about .5 inches. ...</TD></TR></TABLE>
That's bad. The big CV bearing cups plugged into the side of the tranny have room for the axle to move in and out, but the outer end of the axle should be rigidly held to the brake rotor. If you can move the axle it's time to take them out for inspection.
Old Aug 25, 2004 | 11:47 AM
Default Re: autocross at hollywood park (kb58)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb58 &raquo;</TD></TR><TR><TD CLASS="quote">
That's bad. The big CV bearing cups plugged into the side of the tranny have room for the axle to move in and out, but the outer end of the axle should be rigidly held to the brake rotor. If you can move the axle it's time to take them out for inspection.</TD></TR></TABLE>
sorry, im not sure what everything is called, but the actual axle (rod) doesnt move. just that "big CV bearing cup" thats inserted into the tranny (this is the diameter of a coke can right?) well if i put my hand around it and push, it goes in about .5 inches, but on the left side, it only moves in and out maybe a milimeter or so
Old Aug 25, 2004 | 12:54 PM
Greyout's Avatar
Default Re: autocross at hollywood park (duh blacksheep)
.5" is way too much. Did all the fluid leak out?
try tapping it back in...
Old Aug 25, 2004 | 02:31 PM
kb58's Avatar
Banned
Default Re: autocross at hollywood park (Greyout)
Okay good, sort of...
What that means is the CV cup thingy isn't anchored as it should be to the tranny. That's done by snap rings on the cup assembly that snap into the differential, inside the tranny. If you're real lucky, it's just popped out, so give the thing a whack with a soft hammer and a piece of wood to drive it back into the tranny. Just make sure you don't pinch the CV boot and tear it. If it won't click back in place there's a chance the retaining ring came off (inside the tranny) and that means the axle assembly has to come out to put on a new one. The loose retaining ring, probably at the bottom of the tranny, *probably* won't be an issue... except in the case of high-G turns... like at an autocross...
Old Aug 26, 2004 | 05:03 PM
would this cause the car to shake when it is moving? cause the axle itself doesnt move, jsut that cup part.
blasterman87
Nov 30, 2009 08:09 PM
B16b-EJ8
16
Jan 9, 2007 06:01 AM
hondapwr
12
Sep 28, 2005 09:17 AM
disposable
Sep 10, 2005 04:58 PM
bocian
May 18, 2003 10:59 PM
