header question on h22 swap into 92 accord
Old Aug 24, 2004 | 06:36 PM
rlde.us's Avatar
Default header question on h22 swap into 92 accord
I bought myself a 94 h22a swap to put into my 92 accord ex that i just got also. I had check out two different swap how tos, one mentions to use a 93-95 prelude header, the other mentions nothing about needing a different header.
Whats the real answer, and what else do I need to get so there are no suprises for the swap. I know wiring is gonna be a bitch and take more time than the actual engine swap but thats ok.
Heres what I know I need to get
heater hoses, rad hoses, a/c lines, vaccum hose, throttle cable, cruise cable.
and the fuel line, which do I get or do I have to get one made?
I tried searching for some of these answers but couldnt find anything, so sorry if I missed it
Old Aug 24, 2004 | 06:40 PM
v4lu3s's Avatar
RTFM
did hte swap come with a compelte header? if so use that.
and wiring took me less than 1 hour...the accord harness plugs in to just about everything just fine.
anyway i used my stock heater hoses, radiator hoses, a/c lines, vacuum lines, throttle cable, and cruise cable. and then swapped the accord rial and used the stock fuel lines.
Old Aug 24, 2004 | 07:05 PM
rlde.us's Avatar
oh ya, just called my buddy, engine is at his shop has the stock header so thats ok.
but what to do about the map sensor and evap container? also isnt the throttle cable come from the other side on the prelude or something? (might be talking outta my *** he was wondering)
and the fuel line, is the fuel filter on the same side of the firewall as the accord, i see you said use stock fuel lines so Im hoping i have nothing to worry about
thanks again for the good info
Old Aug 25, 2004 | 08:52 AM
rlde.us's Avatar
help =\
Old Aug 25, 2004 | 10:13 AM
v4lu3s's Avatar
RTFM
you use the stock map sensor and stock throttle cable. and you use th stock fuel rail fromt eh f22 to use the stock fuel fitler in the accord.
and you use the stock evap cannister too.
Old Aug 25, 2004 | 12:40 PM
JDMaccord95H22's Avatar
since i bought a JDM h22 the fuel line was a direct bolt up. you can use the previous mentioned way of using a f22 rail or you can use a 97 and up h22 rail or a JDM rail. or extend your existing fuel line.
Old Aug 25, 2004 | 05:47 PM
type-t's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">did hte swap come with a compelte header? if so use that.
anyway i used my stock heater hoses, radiator hoses, a/c lines, vacuum lines, throttle cable, and cruise cable. and then swapped the accord rial and used the stock fuel lines.</TD></TR></TABLE>
about the vacuum lines.....i had one vacuum line left out on the h22 when i did the swap in my 92' accord coupe..i dont know where it goes..its the vacuum up the to the left of the idle control vavle...any suggestion?
Old Aug 25, 2004 | 06:53 PM
rlde.us's Avatar
i got the jdm h22a, so you mean to say it will bolt right up?
if not is there any performance difference between the h22 rail and the f22 rail?
Old Aug 27, 2004 | 01:40 PM
Default Re: (rlde.us)
correct, if you have a JDM motor, the fuel line connects to the driver side of the rail, the same as it does on your existing f22. now if you had purchased a USDM h22 the fuel line connects to the passenger side of the rail and you would have to swap rails or extend your fuel line.
go look and you'll see what i mean, the f22 fuel line bolts to the driver side of the rail, the same as the JDM h22. if you have a JDM motor, you dont have to worry about messing with fuel lines or rails.
and rails dont really add any performance value to your car, i've seen hondas with 500+HP on stock rails, of course the injectors are bigger, but not the rail. the only thing the aftermarket rails are really good for is if you are adding some type of fitting to the rail/fuel pressure gauge. if dont plan on running enormous amounts of horsepower or need the extra fitting holes on the aftermarket rail, dont worry about it.
Old Aug 27, 2004 | 06:05 PM
v4lu3s's Avatar
RTFM
um for a 92 accord it connects on teh passenger side that si why this guy would use the accord rail.
Old Aug 28, 2004 | 05:31 AM
sorry, i skimmed through the first post and saw 94 so i though he had a 5thgen.
Old Aug 28, 2004 | 06:38 PM
rhaccord's Avatar
Default Re: (JDMaccord95H22)
I had an extra vac line also... I just used a tee to one of the connectors on the back of the intake man.
borrego_cd5
Jul 3, 2011 02:08 PM
95EG2
Feb 27, 2011 04:51 PM
doughboi904
Mar 5, 2010 05:46 PM
86lxi-t
Classic Hondas
Nov 23, 2009 11:49 AM
misledyouth
Feb 28, 2003 08:33 AM
