red bulbs for climate control, defroster, hazard in 96-98
Old Aug 24, 2004 | 06:13 PM
lj17's Avatar
Default red bulbs for climate control, defroster, hazard in 96-98
i got an si gauge cluster for my 96 ex and want to change the rest of the bulbs to match. i know this has been done and discussed a million times, but i still have questions.
i have read how to's on painting the bulbs, but i just don't want to do that. so please don't suggest it.
for the climate control, i was just planning on ordering 2 bulbs for a 99-00 si (96-98 only has 2 bulbs, whereas 99-00 has 4) and putting those bulbs in my sockets, if that is even possible (i am assuming they are the same size bulb). the sockets are different, btw. but that still leaves the hazard button and the rear defroster button (and criuse control button, but i am eliminating cruise, so i could care less about that).
the bulbs for the hazard and defroster are VERY small, and you need a flat screwdriver to remove them (they are slotted), or some freakishly long fingernails (for a guy )
the hazard button just uses a clear bulb and then must shine through the red cover so it appears red/amber. i am not sure about this though, because mine has been burnt out since i got my car, so i have never seen it. at any rate, i would think the 99-00 would be the same setup (w/ a clear bulb).
but this is where the problem is- the rear defrost button for the 99-00 is grouped with the a/c and recirculate bottons, and they are all lit with 2 of the larger, climate control sized bulbs. but the defrost on the 96-98 is seperate, and is lit with 2 of the very small bulbs, the same as the hazard. one of my defroster bulbs has a white cover on it, and the other has a blue cover (seemed a little wierd to me). i need those 2 small bulbs to be red/amber. to my knowledge, the 99-00 only uses a total of 2 of the small bulbs- one for the hazard and one for the cruise.
again, i am thinking the hazard uses a clear bulb, like the 96-98. so unless the cruise button uses a red bulb, i don't know what to do. please help!
and if anyone has part #'s, that would be awesome
Old Aug 25, 2004 | 11:40 AM
lj17's Avatar
anyone??
Old Aug 25, 2004 | 11:51 AM
94solchick's Avatar
Default Re: (lj17)
Um, yeah. Ok.
Old Aug 25, 2004 | 02:48 PM
lj17's Avatar
Default Re: (honda94delsolchick)
i know its confusing, but i also know people have changed all their lights to red, and wanted to know how they did it..
Old Aug 25, 2004 | 02:54 PM
Ricey McRicerton's Avatar
Default Re: (lj17)
I did a writeup on this in BauleyCivics Amber lighting thread.
https://honda-tech.com/zerothread?id=661308
Old Aug 25, 2004 | 03:07 PM
lj17's Avatar
Default Re: (Ricey McRicerton)
thanks, can you point me to it?
i already searched, and my 56 gay connection is pissing me off.
EDIT- my bad, the link wasn't showing up before..
Old Aug 25, 2004 | 03:09 PM
FWejCOUPE's Avatar
there isn't much you can do about the hazzard button because it has a red cover on the inside of the button but the rear defroster button is pretty easey, just switch the two small bulbs. there is the one with the blue cap, that lights up white and the one with the white cap actually lights up amber. if you think about it when the defroster is on it is white but when u push the button in there is a little amber light that lights up above it. now the button will light up amber and when it is pushed in the on button will be white.
you can get the 99-00 neo wedge bulbs to do the climate controll but you can't actually use the bulbs, they come with an orange condom on the bulb, just take off the blue on thats on your bulb and put the orange one on.
hope that helps.
Old Aug 25, 2004 | 03:33 PM
lj17's Avatar
Default Re: (FWejCOUPE)
yes it does help, a lot.
i already took out the 2 small bulbs in the defrost and saw the blue and white caps. so the one with the white cap lights up amber, huh? so....i could put 2 bulbs with white caps in and the whole thing would be amber. it seems wierd that they have white caps though...whay not orange like the 99-00 neo wedge bulbs?
p.s.
just wondering, does the 99-00 si cruise control button lite up amber, like the gauges and everything else? if it does, what kind of bulb is in it?
Old Aug 25, 2004 | 04:49 PM
FWejCOUPE's Avatar
Default Re: (lj17)
you could put 2 of the white caps in and bolth would light up amber.
Old Aug 26, 2004 | 01:53 PM
FWejCOUPE's Avatar
here are the pics you asked for, they are a bit blurry. i think they match real well.
just added
79609-s02-a11 thats the honda number for the neo wedge bulb
Modified by FWejCOUPE at 7:52 PM 8/26/2004
Old Aug 27, 2004 | 11:48 AM
lj17's Avatar
thanks a lot. they do match well. but, those neo wedge bulbs (well, covers, actually) are the same as what is in an si, so they should match perfectly, no?
now, you switched the white and blue covered bulbs in the defrost switch, right? it looks like you switched them, but i can't tell for sure...
Old Aug 27, 2004 | 12:51 PM
pdiggitydogg's Avatar
I bought si bulbs from honda and removed the amber condoms from them and swapped em over to my current bulbs
for the defroster I switched the bulbs and removed the blue condom so it was just "naked". Looked better that way to me
Old Aug 27, 2004 | 06:43 PM
FWejCOUPE's Avatar
Default Re: (lj17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lj17 &raquo;</TD></TR><TR><TD CLASS="quote">thanks a lot. they do match well. but, those neo wedge bulbs (well, covers, actually) are the same as what is in an si, so they should match perfectly, no?</TD></TR></TABLE>
yea they are the si bulbs and they'll match good
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lj17 &raquo;</TD></TR><TR><TD CLASS="quote">now, you switched the white and blue covered bulbs in the defrost switch, right? it looks like you switched them, but i can't tell for sure...</TD></TR></TABLE>
yea i switched them
Old Aug 27, 2004 | 08:00 PM
AGENT 99's Avatar
woaa? Where did you get that clock?? Mine just has a hole there
Old Aug 28, 2004 | 12:11 AM
Mike Ockhurts's Avatar
Default Re: (6gcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6gcivic &raquo;</TD></TR><TR><TD CLASS="quote">woaa? Where did you get that clock?? Mine just has a hole there</TD></TR></TABLE>
i believe it came from the euro hondas i THINK
Old Aug 28, 2004 | 12:29 AM
nocturnaldragon's Avatar
Default Re: red bulbs for climate control, defroster, hazard in 96-98 (lj17)
Theres a website that sell led style bulbs for your cluster in just about any color you could want in there, including Uv-Ones, pretty slick im gonna order some when i get more cash it sucks being un-employed
http://www.superbrightleds.com/
Theres an index on the site to, to help you tell what size bulbs you need to if your not sure. If you get some pm me and let me know how they work out for you, im gonna order the blue ones myself.
Old Aug 28, 2004 | 02:08 AM
Icey112's Avatar
some one on here was painting the bulbs.
Old Aug 28, 2004 | 02:16 PM
FWejCOUPE's Avatar
Default Re: (cx Son)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cx Son &raquo;</TD></TR><TR><TD CLASS="quote">
i believe it came from the euro hondas i THINK </TD></TR></TABLE>
yup, its an edm clock
Old Aug 28, 2004 | 02:56 PM
DJ_SaNdOz's Avatar
Default Re: (Icey112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icey112 &raquo;</TD></TR><TR><TD CLASS="quote">some one on here was painting the bulbs.</TD></TR></TABLE>
Yup, I painted the bulbs in my EG red, it looks pretty good. I just need to change the clock to red, and get a new cd player that lights up red.
Old Aug 29, 2004 | 11:55 AM
AGENT 99's Avatar
Default Re: (DJ_SaNdOz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FWejCOUPE &raquo;</TD></TR><TR><TD CLASS="quote">
yup, its an edm clock </TD></TR></TABLE>
EDM? Cool.
edm, jdm, kdm, jeez!
hondaz6lx
Dec 16, 2007 08:17 AM
civic_tuned
12
Jul 16, 2006 08:38 AM
blue92da
16
Feb 10, 2006 04:55 PM
dawrenn
Apr 11, 2005 07:14 AM
