Ignition Red or white line?
Old Aug 24, 2004 | 05:10 PM
mongoliandonuts's Avatar
Default Ignition Red or white line?
when timing the ignition do you set the redline on the cranksshaft to the marker or the white line when i am setting the dizzy to number 1.
Old Aug 24, 2004 | 05:37 PM
devnull's Avatar
White is TDC, red is 16 BTDC. So if you are trying to install the Dizzy you want to have the arrow at white.
Old Aug 24, 2004 | 06:43 PM
b19coupe's Avatar
Default Re: Ignition Red or white line? (mongoliandonuts)
If you are using a basic timing light, adjust the distributor so that the red mark lines up with the pointer. If you are using a timing light with advance capability, dial in the amount of advance that you want (usually ~16 degrees) and adjust the distributor so that the white mark lines up with the pointer.
1990civicdx
Jul 17, 2018 06:13 PM
sohc-8
Dec 26, 2005 04:19 PM
88da3
May 15, 2005 10:40 PM
underpressure02
Nov 29, 2004 05:13 PM
