Tell me about this tubing...
Old Aug 24, 2004 | 04:54 PM
SpeedDreamz.com's Avatar
Default Tell me about this tubing...
what size is this tubing ID and OD? Where do you get the collector like that?
Old Aug 24, 2004 | 05:30 PM
david@didrace.com's Avatar
Default Re: Tell me about this tubing... (30psiCiv)
A little info on who made it would help. Probably 16 gage tubing since it's for a N/A setup.
Collectors aren't that hard to make. It's just 4 cuts per pipe on a 15 degree bend.
Old Aug 24, 2004 | 07:23 PM
Default Re: Tell me about this tubing... (10-94-55)
it is one of Ericks headers. Where can I get 15 degree 16 gauge tubing? What is the size 1.5" ? That is what it looks like to me.
Old Aug 25, 2004 | 07:35 AM
b18cls1's Avatar
its probably 1.5 id 16 ga ss tobing and there are a couple of companys that make collectors like that like hytech and burns and some cheaper ones also look in a summit catalog they have the cheaper ones but you can make one like stated before and cut the pipes at a certin angle and weld thenm together but will never be as good as a true merge collector like a burns,
Old Aug 26, 2004 | 08:03 AM
Ekasey's Avatar
Default Re: Tell me about this tubing... (b18cls1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cls1 &raquo;</TD></TR><TR><TD CLASS="quote">its probably 1.5 id 16 ga ss tobing and there are a couple of companys that make collectors like that like hytech and burns and some cheaper ones also look in a summit catalog they have the cheaper ones but you can make one like stated before and cut the pipes at a certin angle and weld thenm together but will never be as good as a true merge collector like a burns, </TD></TR></TABLE>
^^ Thanks
Seems like it is probably 1 3/4 or 1 5/8 OD You can purchase a collector like that through us or make one yourself.
slowassBubble
Aug 17, 2009 06:13 PM
integraboi2626
Aug 28, 2006 03:31 PM
redrelease
Mar 28, 2006 12:15 PM
88crxhfb16
Jul 20, 2005 08:06 AM
HATCHingMN
Sep 12, 2003 07:23 PM
