Car making squeaky sounds.
Car in question, 1991 honda accord ex-r (ex in the u.s.)
I first noticed this when I made a right turn onto the main street at low speeds, I could hear a high pitched squeak coming from the front driver side wheel area. When I get out of the car and close the door, I notice I can also hear it squeak for a second or two then stop. If I use my foot to push the front driver side wheel in (not kick), it will squeak.
I haven't kicked my other wheels so I'm not sure if it's only the front driver side, but I will check later.
What's wrong with my car? Do I need to go make a video to demonstrate? Thanks.
need more info. does it do when u turn the steering wheel?<<<<<<< air in the sytem
does it do it when u go over small bumps????>>>>>mine turned out to be a fucked up lower bolt joint(its a bitch to change it)
or it can be as easy as bushings >>>>> some silicone spray would fix it.
now that i think about it, about a month ago, when i turned the steering wheel back and fourth (2 cm to each side so not much), it squeaked a bit, the same kind of sound i'm hearing now.
it didn't happen all the time and i haven't noticed it in awhile so i assumed it was just the tire squeaking with the ground.
but yeah, now that i think of it, the sound is very similar, if not the same sound.
FTNW
Jul 7, 2012 04:32 PM
EJ8mike
Feb 15, 2011 08:07 PM
r3000
Dec 20, 2004 09:29 AM
