MIG welding center section of T3
I have a T3 that must be installed on a car I'm building a kit for. The center section has a 1/2" long crack on the side that oil weeps out of slowly. I tried just cleaning it and MIG welding it. That reduced the leak a bit. Now I am redoing it and I was able to just pop the whole patch off with a tap of the air chisel, horrible penetration. So I sandblasted the area clean and heated it up till it was orange and tried MIGing it again. Still leaks. Any suggestions?
I believe cast steel and the filer is mild steel with 25/75 gas. It's been in contact with hot oil for over 14 years so i think it might just be too saturated to get a good bond with the filler. I hate to half-*** things but would any high temp adhesives work temporally?
if you can..drill a small hole at each end of the crack,then use high nicklewire (id use a stick welder) you may also have to gouge the crack a little...just a slight V shap in the crack and pass atleast two times over it...cast wlding is tricky and will not always works right..good luck...is your tuebo taken all apart?...are you rebuilding it?..i have 7 T3 turbos all bad..just hanging out here so if your rebuilding it and need a center give me a yell.............Hal
this is an assembled center with a 60trim compressor, i have to use it
. I might chisle off the last try and try cleaning out the crack like suggested. I think when it heats up the oily smoke if getting in the weld... sucks that I have to use this turbo, oh well a dirty return line never hurt anyone...
O16581724 5 2 5
Jan 11, 2006 12:11 PM
