trailing arms
where can i find upgraded bushings or bushing kits for my 91 hatch trailing arms?
and wondering if i can buy the trailing arms and rear dick conversion intact? does anyone do that?
Rear Disc Converion - Hit your local junkyard. For upgraded bushings..im guessing you mean the polyurethane inserts? Check with Energy Suspension. I'm sure they have some deals over in the suspension/performance Sponsor classifieds.
-Jon
-Jon
you can go with honda, mugen , energy, or prothane for ta bushings.
energy suspension is the cheapest. mugen bushings are a bit stiffer than honda bushings.
prothanes are the easiest to install. for trailing arms hit the junkyard.
i paid like 80 for mine shipped from a "shaun311"
on the performance section
real coo dude hit them up I got mine in two days sweet *** upgrade for launching
and good luck I only found one side with a good ts bushing the other tear out when installing
did you have trouble with the rotted bushings i'll prolly have to torch em huh? and the bolt that they use to adjust the toe setting towars the front of the trailing arm does not wanna let go of that bushing i guess thats what you get for 13 years of neglection.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peichie »</TD></TR><TR><TD CLASS="quote">just installed mine yesterday (on the car that is)
Dude...i could eat off that hub, i see you just got it painted. How about some shots!!!!
</TD></TR></TABLE>Dude...i could eat off that hub, i see you just got it painted. How about some shots!!!!
Holy ****, thats nice as hell, I had the ES bushing master kit, motor mount inserts and just ordered the rear trailing arms before it got totalled.....
WHERE ARE YOUR BUSHINGS FROM?? looks like you GOT ALL OF THEM?....lol sorry for the caps that just looks so nice...
Do you have a link or more pics you could post up?
i installed the entire master kit from energy suspension, added the trailing arm bushings. compensator arm bushings and motor mount inserts are from prothane. i have tubular upper control arms w/ adjustable balljoints, and rear camber adjusters too. i will resize some pics and post them.
btw. did you notice the body work under the hood? every hole, body seams, brackets removed, and all low spots evened out. all that was done by welds, fiberglass or body filler.
i bought them 2 years ago before there were any others available. i got them from a hot rod company that specializes in air ride and hydrollics, they advertise in hot rod magazines.
