Get dougnut gasket flange thing for JDM header, or 2.5 Highflow cat?
Old Aug 24, 2004 | 03:44 PM
98itr0448's Avatar
Default Get dougnut gasket flange thing for JDM header, or 2.5 Highflow cat?
I was looking for some advice. I'm planning on doing a jdm header and a 2.5 exhaust. I was trying to decide wether to get the 2.5 gasket/flange and use my stock cat, or get a 2.5 high flow cat instead. Any help or input on this would be appreciated.
Also, when searching some people said they got a gasket from an S2k for their Headers. Is this all I need to make it fit my stock cat, or will I need anything else?
Old Aug 24, 2004 | 03:48 PM
white rocket's Avatar
Default Re: Get dougnut gasket flange thing for JDM header, or 2.5 Highflow cat? (98Itr-0448)
I will be doing the same set-up in about two weeks. The shop that is doing the install said that they will cut the stock cat and weld a 2.5in collector to it for the header and the T1R 2.5in exhaust will bolt up to the stock cat. If there is a way to not have to cut and weld my cat for the header I would love to know. They also mention that I will be absolutely fine during an emissions test.
I was going to get an aftermarket 2.5in cat(Carsound,etc.) but I've heard and was warned that they crap out quickly. Also, having them say that a stock cat will work fine with this set-up and have no problem passing AirCare(emissions test in Canada) made me think that this route is better for me.
Old Aug 24, 2004 | 03:56 PM
jiahanhao's Avatar
get the high flow... it's worth it
Old Aug 25, 2004 | 08:10 AM
nonvtec's Avatar
Default Re: Get dougnut gasket flange thing for JDM header, or 2.5 Highflow cat? (jiahanhao)
where can i get a cat for a good price?
Old Aug 25, 2004 | 08:25 AM
TypeRPaul's Avatar
dave at smsp does great work...i am running one of his cats
Old Aug 25, 2004 | 08:27 AM
Bbasso's Avatar
Have you called SMSP ?
Dave might be your solution to your problems.
Old Aug 25, 2004 | 08:40 AM
Padawan's Avatar
Darth ModerVader
Default Re: Get dougnut gasket flange thing for JDM header, or 2.5 Highflow cat? (Bbasso)
Definitely SMSP.
Running a modified stock cat would be very restrictive.
Old Aug 25, 2004 | 12:15 PM
skunkintegra's Avatar
Default Re: Get dougnut gasket flange thing for JDM header, or 2.5 Highflow cat? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Definitely SMSP.
Running a modified stock cat would be very restrictive. </TD></TR></TABLE>
VERY restrictive!
Old Aug 25, 2004 | 12:37 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
well, i believe the high flow cats have a bigger overall diameter inside the cat.
Dave @ SMS should be able to clear up your problem. I've ran a hollowed out Stock Cat before..( Peeeyooooo it stunk! black bumpers on PY cars suck )
MOVE OVER
Aug 10, 2006 03:43 PM
schumi
Jul 23, 2005 09:14 AM
98civicEX
Mar 10, 2003 07:42 AM
itr0045
Feb 6, 2002 05:59 AM
