Differences between PR3 and PW0
Old Aug 24, 2004 | 03:42 PM
Reelizmpro's Avatar
Default Differences between PR3 and PW0
From what I gathered PR3 is from the integra b16 and PW0 is from the Civic but what is the difference between the units? different redline?
Old Aug 24, 2004 | 04:00 PM
Change's Avatar
Default Re: Differences between PR3 and PW0 (Reelizmpro)
i think the obd is different.
Old Aug 24, 2004 | 04:39 PM
BR's Avatar
BR
The are essentially the same ECU, as long as you are talking about the obd0 version of the PR3.
I am running the PWO in my setup right now, which I do like better than the PR3, but once you chip it then it is all the same. There is also the fact that the PR3 has WAY more aftermarket support than the PWO does. PWO is also pretty rare compared to the PR3.
Later,
BR
Old Aug 24, 2004 | 04:40 PM
fourthgenhatchB17's Avatar
Default Re: Differences between PR3 and PW0 (BR)
i have a friend that is running the PW0 and it performs fine. He then switched it out for a PR3, and it idled like it had a bad IACV. Anyone know why? BTW, when he went back to the PW0, it ran good as always.
Old Aug 24, 2004 | 05:28 PM
gamakichi77's Avatar
Default Re: Differences between PR3 and PW0 (fourthgenhatchB17)
PWO is more better rather than PR3...but i do not know why?.........anybody can explain it here accurately?
Old Aug 24, 2004 | 05:30 PM
Reelizmpro's Avatar
Default Re: Differences between PR3 and PW0 (acidburns_di)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acidburns_di &raquo;</TD></TR><TR><TD CLASS="quote">PWO is more better rather than PR3...but i do not know why?.........anybody can explain it here accurately?</TD></TR></TABLE>
I've heard the opposite. No one seems to have an definitive answer.
Old Aug 24, 2004 | 05:40 PM
daidilus's Avatar
there are b16a from integras and crx/civic if you have a integra b16 you need a PW0, and the PR3 is for the civic/crx....the lines on the intake manifold are different
Old Aug 24, 2004 | 05:47 PM
StupidSlowRSX's Avatar
Default Re: Differences between PR3 and PW0 (daidilus)
I think..
the JDM CRX Ecu has a vtec crossover set at 4900 RPM
where as the integra ECU's crossover is set at 5200
Old Aug 24, 2004 | 07:24 PM
87b16crx's Avatar
the pr3 is from an integra that has a cable speedo. the pw0 is from a civic/crx with an elecronic speedo. they send the pr3 with b16's because all of our cars have a cable speedo. i have read that vtec wont enguage if the car is traveling under 3mph unless you have a vtec controller. and if you want to hook up a jdm cluster, you need the pw0 ecu, from what i have read at least.
Old Aug 26, 2004 | 10:21 AM
smart monkey's Avatar
PR3 and PW0 are all about the same. A friend of mine who is a tuner says the PW0 is more tuner friendly but all in all the same. the speedo issue does not matter as the us civics have the vss in the cluster.
Old Aug 28, 2004 | 01:55 AM
nominous's Avatar
Default Re: Differences between PR3 and PW0 (smart monkey)
The PR3 is likely the rarer ECU. It only came in the Integra XSi as far as I know.
The PW0 has several varients. The main one being the PW0-000 for JDM CRX SiR and PW0-E00 (or PW0-X00) for EDM cars (or civic SiR / EDM VT civic)
The PW0-000 has a knock sensor board and its stock mapping is slightly different to the PW0-E00.
Over on pgmfi, there is the seemingly the same amount of development for the PW0 as the PR3, but more locations in the ROM have been mapped for PW0.
Although the SiR has a VSS on the tranny rather than the cluster, this matters not to the ECU as long as it gets a signal from one of them. You can run a PW0-E00 in a true SiR but not a PW0-E00 in a EDM VT crx since it wants teh knock sensor connected.
The PW0-000 as stock also has a 112mph limiter, I would imagine the PR3 has the same limiter.
Old Oct 4, 2004 | 05:42 AM
Default Re: Differences between PR3 and PW0 (nominous)
I know im bring back an old thread by doing this but oh well..
The PR3 doesnt activate vtec if you a light on the gas. THis is to charish fuel efficency when your doing 80 mph on the high and vtec doesnt turn on, but if you give me 1/4 throttle or more, it turns on..
My budddy had a Pw0 and he says his vtec turned on no matter what throttle he was using, when 5200rpm came it switched over
Old Oct 4, 2004 | 06:13 AM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (87b16crx)
it's weird but my dad's 89 civic LX sedan DPFI came with a PWO and a standard D15B2 stick shift. it had cable speedo. the motor was'nt vtec
Old Oct 4, 2004 | 08:18 AM
Default Re: (JC18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JC18 &raquo;</TD></TR><TR><TD CLASS="quote">it's weird but my dad's 89 civic LX sedan DPFI came with a PWO and a standard D15B2 stick shift. it had cable speedo. the motor was'nt vtec </TD></TR></TABLE>
i have an obd0 lx ecu ill trade for your dads pw0 :]
Old Oct 4, 2004 | 09:04 AM
Origin's Avatar
Default Re: (StupidSlowCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX &raquo;</TD></TR><TR><TD CLASS="quote">I know im bring back an old thread by doing this but oh well..
My budddy had a Pw0 and he says his vtec turned on no matter what throttle he was using, when 5200rpm came it switched over</TD></TR></TABLE>
i just drove my crx with the Pw0 and it does engage vtec at 5200 no matter what throttle. just backing you up
Old Oct 4, 2004 | 10:41 AM
DieMaster's Avatar
i have an obd0 lx ecu ill trade for your dads pw0 :]</TD></TR></TABLE>
i would love to do bisnessus but we donated that car to a red cross thing as a tax wrightoff about 6 months ago. if i knew then what i know now, i'd would have put my PM5 in there and kept the PWO
so i sont have it only the PM5 i rely on for a daly driver
gtarwiz
Feb 14, 2005 11:43 AM
Young_Matthew
Jul 6, 2004 01:24 AM
dand39
Oct 12, 2003 10:38 AM
johnzm
Jul 23, 2002 10:19 AM
