Annoying Rattles
There is this annoying rattling sound coming from around my headers. Any ideas on what it could be... I took the heat sheild off and it still does it! 94 Prelude SI Ideas? Thanks!
im begining to think staticrex is right. the sound is coming from the valve area. what does an adjustment consist of and how much does it normally cost to get done? any info on the subject would help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugen88crx »</TD></TR><TR><TD CLASS="quote">im begining to think staticrex is right. the sound is coming from the valve area. what does an adjustment consist of and how much does it normally cost to get done? any info on the subject would help!</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=618786
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex »</TD></TR><TR><TD CLASS="quote">Could be your valves need adjustment.</TD></TR></TABLE>
I found several brackets loose... so I removed them, but the sound is still there. I think the write up on the valve adjustment is great but im not good enough to do it myself. How much do you think it would cost for a local shop to do it? AVERAGE
Do you have a DC header??
Also check the heat sheilds running along the length of the exhaust..it sounds like its near the engine, but could be the exhaust...
vavle clatter is usally a ticking sound, not a rattle. if its a rattle that comes and goes then its a sheild. If there is a constant ticking, then you need a valve adjustment. the shop i use blasts through valve adjustments in like 5 mins tops, just depends what their labor charges are.
kwazigoku
May 16, 2007 07:29 PM
ej2civic
Oct 2, 2005 09:43 AM
deconstruct
23
Jun 29, 2004 09:31 AM
