ecu problems.
Old Aug 24, 2004 | 09:03 AM
vtfootball54's Avatar
Default ecu problems.
alright well i decided my si crx wasnt as fast as i wanted it so i wanted to put an zc ecu in it but i ended up getting a ls ecu. so i put that in and it worked good. except that it idled around 1 1/2 and to 2 thousand rpms all the time. than i took it on the highway and the check engine light came on and the code was 43 the fuel supply system. does anyone know y that happened and how it could be fixed.
Old Aug 24, 2004 | 09:24 AM
4drEF's Avatar
Keyboard Humorist
Default Re: ecu problems. (vtfootball54)
Switch back to your stock ECU and see if the code goes away.
If the code comes up on the stock ECU then get a service manual and trouble shoot the fuel system.
Old Aug 25, 2004 | 09:27 PM
Default Re: ecu problems. (4drEF)
i put the stock ecu back in and it went away. but when i had the ls ecu in it. it felt like i had more power. so is there anyway to fix the problem with the other ecu. or should i just go and try and find an zc ecu
Old Aug 25, 2004 | 09:36 PM
em Dot's Avatar
POOPCheeks
it might be that your're running too rich on gas b/c the ls needs more gas to run. my friend had the same problem but reverse. he had a cx ecu in his ls hatch. he ran too lean on gas. i'll ask him what he did and get back to you
Old Aug 27, 2004 | 09:10 PM
Default Re: ecu problems. (em Dot)
alright thanks. just let me know what he did.
da9blk1
Jul 19, 2010 08:04 PM
nmhuntr
Jun 10, 2008 12:07 PM
danteisme
Nov 2, 2007 02:25 PM
SpoonFedEF7
May 19, 2004 12:01 AM
kim_2_da_chee
May 30, 2003 06:18 PM
