code 14 ...what voltage should each iacv wire be getting??
Old Aug 24, 2004 | 08:04 AM
b16acrxer's Avatar
Default code 14 ...what voltage should each iacv wire be getting??
i have a code 14 in my 88 civic lx and both wires are getting no voltage at all....and sometimes but not at the present time i get code 10 (iat) i checked the votages for that just now and red wire is getting 5v. is that good or should it be 12?
Old Aug 24, 2004 | 08:19 AM
rsbad454's Avatar
Default Re: code 14 ...what voltage should each iacv wire be getting?? (b16acrxer)
should be 12 volts....Blue/Yellow is a negative return to ECU pin A11 while the Black/Yellow is +12.
Old Aug 24, 2004 | 08:58 AM
b16acrxer's Avatar
Default Re: code 14 ...what voltage should each iacv wire be getting?? (rsbad454)
well then i guess ill run new iacv and iat wires to the ecu....which wires goto what pins?
thanks
ronnie O
Old Aug 24, 2004 | 09:10 AM
4drEF's Avatar
Keyboard Humorist
http://www.fourthgenhatch.com/mpfi.html
Old Aug 24, 2004 | 11:51 AM
b16acrxer's Avatar
Default Re: code 14 ...what voltage should each iacv wire be getting?? (4drEF)
what about iat??? which wires go from iat sensor to ecu that table doesnt say
Old Aug 24, 2004 | 11:56 AM
rsbad454's Avatar
i thought LX was already MPFI right? why would you have to run new wires? you need to trouble shoot. Do you have a FSM?
Old Aug 24, 2004 | 12:06 PM
b16acrxer's Avatar
ugh!!! i am troubleshooting...no lx's are dpfi....no voltage going from ecu to sensors so im running new wires for them....i was wanting the pin locations for the IAT sensor
Old Aug 24, 2004 | 12:10 PM
EP3_05's Avatar
If you can wait until maybe 8:00 est tonight I can go home and look at my FSM wiring diagrams and let you know the pin locations but hopefully someone can come through with the locations before that.
Old Aug 24, 2004 | 05:40 PM
b16acrxer's Avatar
Default Re: code 14 ...what voltage should each iacv wire be getting?? (91civic)
thanks
Old Aug 26, 2004 | 07:14 AM
IVI's Avatar
IVI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">If you can wait until maybe 8:00 est tonight I can go home and look at my FSM wiring diagrams and let you know the pin locations but hopefully someone can come through with the locations before that.</TD></TR></TABLE>
did you ever post up the locations? i need them as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16acrxer &raquo;</TD></TR><TR><TD CLASS="quote">ugh!!! i am troubleshooting...no lx's are dpfi....no voltage going from ecu to sensors so im running new wires for them....i was wanting the pin locations for the IAT sensor</TD></TR></TABLE>
did you figure it out yet?
im having the exact same problem with both sensors. the iat, and iacv.
Old Aug 26, 2004 | 07:40 AM
b16acrxer's Avatar
Default Re: code 14 ...what voltage should each iacv wire be getting?? (IVI)
no i havent figured it out yet.
Old Aug 26, 2004 | 09:24 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16acrxer &raquo;</TD></TR><TR><TD CLASS="quote">what about iat??? which wires go from iat sensor to ecu that table doesnt say</TD></TR></TABLE>
IAT is the Intake Air Temperature
TA is what I have seen Honda call the actual sensor - Temperature Air.
You can find that on the pin out list in the link I posted before.
Old Aug 26, 2004 | 10:31 AM
bambam's Avatar
ur car is an 88....the wiring for ur eacv is different than the 89-91 s
first try unpinning A17 at the ecu and tell me how that works out...
CrX EnTHUSIAST
May 1, 2017 08:39 AM
noender
Dec 5, 2010 12:08 PM
miller.91.HB
May 25, 2004 09:50 PM
JonGP4
Jul 26, 2003 06:13 AM
