Car bogs under high rpm/boost. Sometimes.
Old Aug 24, 2004 | 05:26 AM
JDMTurboCivic11's Avatar
Default Car bogs under high rpm/boost. Sometimes.
Ok well it happenes every once in awhile , but yesterdays case ; i was in 5th gear at about 3-4k and my car started to bog. felt as if it was mis-firing maybe?? Im just not sure what else it would be or how would i fix that problem. If it is misfiring should i retard the timing some more?
Old Aug 24, 2004 | 05:40 AM
xrunner86x's Avatar
Default Re: Car bogs under high rpm/boost. Sometimes. (JDMTurboCivic11)
I was having a problem like that. My ignition and fuel tables didnt agree at 5mmhg vacuum, which was about the rpm you said. What management are you using?
Old Aug 24, 2004 | 05:43 AM
Default Re: Car bogs under high rpm/boost. Sometimes. (xrunner86x)
Right now its untuned and using a VAFC with 12:1fmu, stock injectors.
Old Aug 24, 2004 | 05:49 AM
xrunner86x's Avatar
I thought if you used a VAFC you ditched the FMU, but id get it tuned. Where is your vtec engagement set at? That was another part of my problem, it was actually a hondata glitch with the vtec changeover keeping the pre-vtec maps or something.
Old Aug 24, 2004 | 06:04 AM
I belive you ditch the fmu when you use the vafc hack. with the dsm's.. But right now my Vafc Cor: is set to 0% all across. my vtec i belive is kicking in at 5k RPM
Old Aug 24, 2004 | 06:18 AM
-Trinitron-'s Avatar
I had similar issues. Turned out to be fuel pressure. Cranked it up a little, and voila!
Old Aug 24, 2004 | 07:55 AM
vaporboy12's Avatar
maybe you lean out under lots check the gap on your spark plug gap maybe the spark is getting blown out
totsie7944
Aug 30, 2005 02:59 PM
Daily Interlude
Nov 5, 2004 06:11 AM
TGUNNER
Apr 18, 2003 10:19 AM
KC GSR
Aug 31, 2002 10:51 AM
GOKOU
Aug 16, 2002 05:56 AM
