98 Prelude Amplifier Remote Wire
Old Aug 24, 2004 | 05:04 AM
macaronak's Avatar
Default 98 Prelude Amplifier Remote Wire
I just installed a 350 watt kenwood amplifier pushing a single 10" JL W0. At times the amplifier works fine with no problems but sometimes after i turn the car off and try and turn the car back on the next day the amp wont turn on. Does anyone have any idea what maybe the problem. I was thinking it was the Remote Wire as i have it connected with a fuse in the fuse box? Anyone have a better idea of where to connect the remote wire as I do not have an after market headunit and i do not have a power antenna. Thanks
Old Aug 24, 2004 | 04:56 PM
the_crowbar's Avatar
Default Re: 98 Prelude Amplifier Remote Wire (macaronak)
In my car, I put a mini switch in the dash (below the moonroof/dimmer/cruise switch) and ran that back to the amp. I have a computer instead of a regular head unit so I wanted to have more control over when the amps turn on. If you think the problem is with the amp control wire, turn the car on and test with a multimeter. I fear I may be getting too basic, but the amp needs +12v on the signal wire (usually a blue wire) to turn on.
HTH
the_crowbar
sooo_slow
Audio / Security / Video
Feb 28, 2005 03:21 PM
ChaosUnbound
Feb 24, 2004 04:20 PM
Understeer
Apr 18, 2003 09:15 PM
turbomonkeyexpress
Jan 2, 2003 01:55 PM
TeG cRaZy
Jul 1, 2001 02:03 AM
