JDM ITR Front end conversion...
Old Aug 23, 2004 | 10:57 PM
JDM knowledge's Avatar
Default JDM ITR Front end conversion...
OK poeple i know for a fact that since this oh so wonderful welding sub-forum was created that probably the most looked for topic will be for a JDM ITR front end conversion. Since this forum is relatively new, compared to say...the EG6 forum, i would really really really like for a moderator to start the most looked for sticky thread. Or at least sticky the front end converison one. I did a few searches on here but they dont have a step by step process with pics. WE need pics! Here is one i found searching around.
http://tech.wiredspeed.com/jdm_front.asp
please of u can and are willing to...post more helpful links on this DIY. People charge $300 bucks here in Florida just to cut and weld the rad support.I know i need it what about you?
Old Aug 23, 2004 | 11:32 PM
B18Tahtaras's Avatar
Default Re: JDM ITR Front end conversion... (JDM knowledge)
Damn, i didn't know soo much work was involved...
Old Aug 24, 2004 | 06:05 PM
so simple's Avatar
yes more detailed pics / help. its about clost to $500 here in sf bay area
Old Oct 27, 2004 | 01:48 PM
Bay_707's Avatar
Default Re: JDM ITR Front end conversion... (simpleaznx)
one shop will do it for 100 other for 200 in norcal
Old Oct 27, 2004 | 02:49 PM
so simple's Avatar
what shop is this? what does the work consist of ? do they just cut and weld, we have to take off own fenders,bumpers etc. or do they test fit everything? thanks
Old Oct 27, 2004 | 05:48 PM
DragII's Avatar
25 Year Member
Default Re: (simpleaznx)
all you have to do is drill out a few spot welds, and remove the top half of the support, then either bolt, or weld the jdm top half in it's place its really pretty easy. I did it myself in like an hour, and everything lined up perfect first try.
Old Oct 31, 2004 | 09:43 AM
53JDMDC2's Avatar
i went so much further than that. I cut out all the spot welds and took the whole front off. a lot more work involved this way but in the long run will look factory.
Old Oct 31, 2004 | 05:52 PM
so simple's Avatar
i heard that its not as safe changing the entire radiator support, because your new welds wont hold up as well as the original ones? shrug
Old Nov 1, 2004 | 04:34 PM
Benbuilt4u's Avatar
i charge 500 and ive done many in my area
Old Nov 1, 2004 | 09:57 PM
eastbay92cx's Avatar
Default Re: JDM ITR Front end conversion... (Benbuilt4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">
please of u can and are willing to...post more helpful links on this DIY.</TD></TR></TABLE>
That link you gave seem like plenty of info to me, exactly what you need to get the job done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by simpleaznx &raquo;</TD></TR><TR><TD CLASS="quote">i heard that its not as safe changing the entire radiator support, because your new welds wont hold up as well as the original ones? shrug</TD></TR></TABLE>
Can you weld? hehe just kidding ... sure a good plug weld or welding along the seams will be anywhere from just as strong to a lot stronger than the factory spot welds. Just depends on how far you're willing to go to hide everything and make it look like you didn't weld it on IMO.
Old Nov 1, 2004 | 10:08 PM
gldndrgn14's Avatar
Default Re: JDM ITR Front end conversion... (eastbay92cx)
anybody man or body shop should be able to do it. its basically a simple front radiator support change. like if you got in a wreck theyd have to change it if the radiator support was bent anyway. its not hard. its made to beable to change.
Old Nov 2, 2004 | 07:54 AM
53JDMDC2's Avatar
I crashed so i had to change the whole rad support anyway. But my welds are plenty strong. I have done frame rails on full race mustangs and nothing has fallen apart.
Formula
Mar 2, 2014 03:45 AM
Ls-Turbo
Jul 2, 2005 12:28 AM
capcon83
Feb 23, 2003 02:03 PM
Tiwe
Aug 30, 2002 10:29 PM
