hard changin gears?? PLEASE HELP!!!!
Old Dec 3, 2001 | 06:54 PM
integra81's Avatar
New User
Default hard changin gears?? PLEASE HELP!!!!
i just noticed when switch gears its not as smooth as it used to be. it seems like it happend all of a sudden. It happens in every gear. i dont know how to explain it but it just seems like its "Choppy" goin into gears, like its not smooth goin into and out of gears. what can this be. please help. it really doesnt feel right!!
Old Dec 3, 2001 | 08:50 PM
rioninja's Avatar
Default Re: hard changin gears?? PLEASE HELP!!!! (integra81)
Change your tranny fluid with some Honda MTF. It could be a lot of things, but start from there.
Old Dec 3, 2001 | 11:13 PM
BuddhaSiR's Avatar
Default Re: hard changin gears?? PLEASE HELP!!!! (RioNinja)
It's probably your Clutch goin out. What does your clutch feel like??? Also try adjusting your clutch cable. i have run into this problem before. If your clutch cable has to much slack in it your pressure plate isn't disengaging all the way.
[Modified by BuddhaSiR, 8:16 AM 12/4/2001]
Old Dec 3, 2001 | 11:26 PM
Piston_Honda's Avatar
New User
Default Re: hard changin gears?? PLEASE HELP!!!! (BuddhaSiR)
Integra81, when you shift, does it sometimes grind? I have problems similar to yours, but my gears grind.
Old Dec 4, 2001 | 03:21 AM
integra81's Avatar
New User
Default Re: hard changin gears?? PLEASE HELP!!!! (Piston_Honda)
yes sometimes it does grind. is usually when i rev up high. sometimes it grinds at low rpms but mostly at higher rpms
Old Dec 4, 2001 | 10:32 AM
Mista Bone's Avatar
D Tranny Guru
adjust the clutch cable first and check fluid level in the tranny.
Is it just 1-2 shift, or 2-3 shift, or all gears?
Old Dec 4, 2001 | 12:46 PM
BoostedED9's Avatar
Default Re: hard changin gears?? PLEASE HELP!!!! (Mista Bone)
sometimes on my tranny I can hardly put it into 1st gear,but after i get moving i can get into gears fine wiht a small grind from letting clutch out too early.... I have adjusted the cable to its max and i have a act heavy duty plate and street/strip disc.. any sugestion???
Old Dec 4, 2001 | 01:27 PM
Trinity's Avatar
Default Re: hard changin gears?? PLEASE HELP!!!! (ED9Hybrid)
i ran into the same problem with my car and me and rio ninja though of everything but came up with nothing and then it just fixed itself. the only thing i can think of is that your clutch isn't disengaging all the way causing it to grind
Old Dec 4, 2001 | 06:35 PM
integra81's Avatar
New User
its ever gear
Old Dec 4, 2001 | 07:11 PM
RedRacerCivic's Avatar
sounds like time to replace tranny oil with OEM honda tranny oil. I did that and it helped my shifting and almost stopped grinding at higher RPM.
Old Dec 4, 2001 | 07:49 PM
AfEn808's Avatar
New User
Default Re: hard changin gears?? PLEASE HELP!!!! (RedRacerCivic)
I think its time to replace your tranny or synchro and hubs not your tranny fluid honda trannys usually start grinding going into third because my s1 is starting to and a guy I know replaced his tranny three times because of the third gear grinding.
killafred187
Nov 6, 2009 12:38 PM
b18sihatch
Jan 15, 2006 07:13 PM
keVerns
Jun 28, 2004 12:20 AM
Incubus05
Feb 14, 2004 07:29 PM
spooned out
Sep 4, 2003 10:19 AM
