y1 trans
I just did a b16 swap into my 90 crx my trans is leaking fluid from the passenger side where the axle goes in whenever i put fluid in it. What could be causing this problem?
My guess is that when you installed the axle, the rubber piece holding the fluid back became dislodged. Have you pulled the axle out to inspect it yet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littledevil46 »</TD></TR><TR><TD CLASS="quote">i just got it all together and put fluid in it. it leaked out. if the axle is not in would the fluid leak out</TD></TR></TABLE>
Yes, you need to put the axle into the tranny before you put in the fluid.
With the Y1 tranny, I know that you will need to use a SiR axle on the drivers side if you are using the Y1 half-shaft. I'm not too sure if you also have to use a SiR axle on the passenger's side as well. That maybe the reason that it leaks as the Integra shaft maybe too short to seal properly. I would change the seal first and see if that remedies your problem.
gsxr1k05
11
Mar 2, 2009 01:33 PM
redpeppers
May 16, 2006 11:17 PM
