Bets spark plugs for Nitrous....
Old Aug 23, 2004 | 08:30 PM
Dumped DB2's Avatar
Default Best spark plugs for Nitrous....
Im putting a NX wet kit on my integra by the middle of the week and I am currently running 2 month old Bosch Platinum +2's(I know they are garbage) and NGK OEM wires...My question is what would be the best type of plug for my engine such as copper or iridium? 2 people have told me so far that platinums are not good at all and will be toast in a short period of time...How long could I stay with the Boschs before they take a dump?
Old Aug 23, 2004 | 09:37 PM
3.504's Avatar
Default Re: Best spark plugs for Nitrous.... (Pjct2ndGenTeg)
recommended plugs for nitrous are coppers that are 2 degrees colder for between 50-75shot. nitrous ***** out plugs quick.... better to use cheaper plugs regardless if you plan to spray alot (going to the track that day.) i used NGK or champion coppers before. i dont remember the numbers though... you might have to get with the manufacterer to get a sheet that tells you which plugs are for your motor that are 2 degrees colder. you also want to run some retard if you're using a higher shot, 50 will be fine for stock base timing, but i'd say back'er off if you jump into the 75+range
Old Aug 23, 2004 | 09:56 PM
shermanyang's Avatar
Default Re: Best spark plugs for Nitrous.... (3.504)
try some NGK 3330 and gap them to about .030
Old Aug 24, 2004 | 01:32 PM
Dumped DB2's Avatar
Default Re: Best spark plugs for Nitrous.... (shermanyang)
I picked up some NGK's today....Thanks for the help guys!
lude98SH
Jun 24, 2007 02:39 PM
tegon-gsr
Jun 4, 2004 11:44 AM
sting94112
Apr 18, 2004 04:26 AM
WNT KCH
Sep 19, 2001 09:25 AM
