accord timing belt issues
Old Aug 23, 2004 | 08:01 PM
stevescivic's Avatar
Default accord timing belt issues
today my friend and I were putting his 92 accord with the f22 engine back together after replacing the timing belt. All was good but we were left with an extra washer from somewhere and I can't figure out where it belongs.
I would assume that this is the order of pieces that go on the idler pulley shaft.
Timing belt tensioner
balance belt tensioner
adjusting nut
Is there a washer that goes anywhere in the above pieces?
I don't think there are ANY washers that belong to the timing belt/balance belt area. Am I correct in assuming this? I have the factory service manual and I don't see any washers anywhere.
Thanks
Old Aug 23, 2004 | 08:05 PM
Default Re: accord timing belt issues (stevescivic)
one more thing... when remounting the crank pulley is the surface of the inside of the pulley supposed to be flush with the crankshaft or is it suppose to be a bit raised from the crank?
thanks
Old Aug 24, 2004 | 09:12 AM
lance351's Avatar
i just put a timing belt on a 96 2.2 and my crank pulley wasn't flush with the crank hope this helps
Old Aug 24, 2004 | 08:03 PM
cmrvi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevescivic &raquo;</TD></TR><TR><TD CLASS="quote">I would assume that this is the order of pieces that go on the idler pulley shaft.
adjusting nut
Is there a washer that goes anywhere in the above pieces?</TD></TR></TABLE>
The washer goes on between the T-belt tensioner and the nut.
Old Aug 24, 2004 | 08:05 PM
cmrvi1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevescivic &raquo;</TD></TR><TR><TD CLASS="quote">one more thing... when remounting the crank pulley is the surface of the inside of the pulley supposed to be flush with the crankshaft or is it suppose to be a bit raised from the crank?</TD></TR></TABLE>
Did you remember to install the belt guide on the crank before the crank pulley?
Old Aug 25, 2004 | 10:14 AM
jrw2scw's Avatar
On my 93 accord there is a flat washer that is in front of the belt tensioner apparatus.. Hope this helps...
crvglenn
Honda CR-V & Element
Aug 20, 2017 01:44 AM
us31wking
Aug 21, 2014 04:50 AM
hmtcrxsir
Dec 22, 2009 10:21 AM
slayerP
Apr 8, 2006 05:21 PM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
