Valve cover problem!
I could not find how many pounds of torque I should use to tighten down these bolts.
So I did about 20. With a aluminum block I figured it would be ok.
On one of the bolts I felt it give a little bit as soon as it did I STOPPED. I hooked it all back up and reved it and ran the hell out of it and its not leaking or anything, But is it ok or did I strip out somthing that I cant fix?
