WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE?
Old Aug 23, 2004 | 06:26 PM
1stGENGSR's Avatar
Default WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE?
I know this has been covered before, but I'm curious how many have actually done this on their own since Omniman and Rocket informed eveyone that it could be done a while back.....And primarily what kind of washer did you have to shim it with if any, what material was it made of........AND MOST IMPORTANTLY : Have you had any problems with it??? I have NO DOUBT it works soley because two VERY reputable engine builders, etc. said it does, but I have been told it's a bad idea by others, so I'll take whatever feedback you guys have......................... OR
Old Aug 24, 2004 | 12:27 PM
1stGENGSR's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (1stGENGSR)
NOBODY??? I'm in disbelief........
Old Aug 24, 2004 | 12:36 PM
hondaguyef's Avatar
contact a user by the screen name of: alternativeauto I know he uses this method
Old Aug 24, 2004 | 12:59 PM
BERT-O's Avatar
Only on 2 local cars in this area, non are members of this board.
Why?
Old Aug 24, 2004 | 01:12 PM
Grip's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (BERT-O)
what are the pro's of this"method"? ive never heard of it until now
Old Aug 24, 2004 | 01:49 PM
1stGENGSR's Avatar
I want to know if there are any unmentioned possible problems with doing this , cause I'm contemplating doing it in my B17........GSR or Type R LMAs are at least $250, the prelude deal is only about $60-$80.......I don't know about you guys, but I like to save money as long as the outcome is desirable.........I mainly wanted to see what kind of sucess people have had with this (good fitment, longevity, etc.) as Omni only posted how to do it and that it was possible:https://honda-tech.com/zero...
Old Aug 24, 2004 | 03:33 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O &raquo;</TD></TR><TR><TD CLASS="quote">
Why?</TD></TR></TABLE>
i'm a member, and i have done the mod. so far so good, i haven't noticed any ill effects. i think since i put them on, i have ran over 40+ passes at the track. as well as driven hundreds of miles, i hope this helps you out
Old Aug 24, 2004 | 04:58 PM
1stGENGSR's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (smokey2.0)
What motor did you run them in? Did you have to shim them with some kind of paper thin washer (.040")?
Old Aug 24, 2004 | 05:38 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1stGENGSR &raquo;</TD></TR><TR><TD CLASS="quote">What motor did you run them in? Did you have to shim them with some kind of paper thin washer (.040")?</TD></TR></TABLE>
the washers i used, you can buy at your local hardware store. the lma's are in a b16 head, and i haven't noticed any weird noices!
Old Aug 24, 2004 | 06:05 PM
LSVTEC 91 Civic's Avatar
Banned
School me up, I plan on replacing my LMAs, might try this.. What did you have to modify? How did you install them?
Old Aug 24, 2004 | 07:25 PM
1stGENGSR's Avatar
Cool deal, Omni is da ****! LS Vtec: Click on the link in the middle of the thread, in my third post......
Old Aug 24, 2004 | 07:45 PM
ATS*Mark's Avatar
OG triple OG
is there a performance gain to this , or is this strictly a money saving mod?
Old Aug 24, 2004 | 07:52 PM
ninor's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (Hella_JDM)
money saving is the primary reason... when it comes to properties they are very similar to itr ones and will handle major lift cams...
Old Aug 24, 2004 | 08:23 PM
1stGENGSR's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (ninor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninor &raquo;</TD></TR><TR><TD CLASS="quote">money saving is the primary reason... when it comes to properties they are very similar to itr ones and will handle major lift cams...
What he said...............
Old Aug 24, 2004 | 08:27 PM
smokey2.0's Avatar
TRUE
Old Aug 24, 2004 | 11:21 PM
TREVER's Avatar
I did it. it works fine
Old Aug 25, 2004 | 03:05 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (TREVER)
I don't think Omni and Rocket would have recommended it if there were any reliability issues.
Old Aug 25, 2004 | 03:27 AM
Banned
I did, I dont see anything. I've never replaced the LMAs before, anybody have a DIY LMA replacment with H22 LMAs, to break it down barney style? Thanks I need .040 steel washers and a set of lude H22 LMAs, but I'm not really sure how it all goes together.
Modified by LSVTEC 91 Civic at 12:48 PM 8/25/2004
Old Aug 25, 2004 | 08:02 AM
2point6's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (LSVTEC 91 Civic)
This set-up works well, manny. I just started doing this on all the new engines. The spring shares the same tension as the ITR, but sits .040" lower in the seat. (as already stated) the washers can be found at a local hardware store. This will work well in your b16 bead.
Old Aug 25, 2004 | 09:00 AM
C2Imports's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (2point6)
waste of money, your all wasting money.... joe alaniz of alaniz technologies and tom @ portflow both said replacing LMA's for use with high lift cams is not necessary, ive done both, used ITR lma's and im currently running my first gen b16 lmas with no ill effects, my cams have a lot of lift and I shift @ 9k, no problems, unless your lmas sound like ****, dont do it. Just my 2 cents.
Old Aug 25, 2004 | 02:28 PM
fourthgenhatchB17's Avatar
Default Re: WHO HAS SUCCESSFULLY USED OMNI'S METHOD... H22 LMAs IN A B-SERIES ENGINE? (towsondragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by towsondragcrx &raquo;</TD></TR><TR><TD CLASS="quote">waste of money, your all wasting money.... joe alaniz of alaniz technologies and tom @ portflow both said replacing LMA's for use with high lift cams is not necessary, ive done both, used ITR lma's and im currently running my first gen b16 lmas with no ill effects, my cams have a lot of lift and I shift @ 9k, no problems, unless your lmas sound like ****, dont do it. Just my 2 cents. </TD></TR></TABLE>
If first gen LMA's work fine with high lift cams, then why do type R motors have LMA's with a different p/n? Why would Honda use different LMA's and not just 1 for all b series?
Old Aug 25, 2004 | 03:31 PM
BERT-O's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 &raquo;</TD></TR><TR><TD CLASS="quote">
i'm a member, and i have done the mod. so far so good, i haven't noticed any ill effects. i think since i put them on, i have ran over 40+ passes at the track. as well as driven hundreds of miles, i hope this helps you out </TD></TR></TABLE>
lol, I meant my local town
Old Aug 25, 2004 | 03:45 PM
smokey2.0's Avatar
i was just being sarcastic
Old Aug 25, 2004 | 04:04 PM
1stGENGSR's Avatar
I'm replacing LMAs that have a QUARTER OF A MILLION miles on them.....It's an investment at this point.......Stock replacements for my B17A are the same price as Type R about $35.00 APIECE! Multiply that by eight and you spent enough to buy an aftermarket intake manifold......To do the Prelude deal costs LESS than $100.00 TOTAL! No WASTING goin on here, Just SAVING! BUT just to put it out there, Type R LMAs have alot more surface area for the rocker to sit on........--------------------------------------------------------------------------------
Old Aug 25, 2004 | 04:13 PM
1stGENGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">I did, I dont see anything. I've never replaced the LMAs before, anybody have a DIY LMA replacment with H22 LMAs, to break it down barney style? Thanks I need .040 steel washers and a set of lude H22 LMAs, but I'm not really sure how it all goes together.
Modified by LSVTEC 91 Civic at 12:48 PM 8/25/2004</TD></TR></TABLE>
All you need to do is look at the pic above, Typical LMA os on the left : Type R is on the right.....Underneath your rocker arms you will see one of these on each side of each cylinder. One on the intake side and one on the exhaust side. You have to take the cams and rocker shafts out to remove them.......Plus all other stuff that's in the way (cam journals, valve cover, you get the idea.....). Look at the pic below and you'll see where they are located.....................--------------------------------------------------------------------------------
